Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Is it ok to leave the USB plugged in all the time?
  • 506 Answers
You can leave the USB disk plugged as long as you want but alway remember to safely remove the disk from the software level before unplugging the USB disk.
Posted on Aug 24, 2010
Is it ok to keep my usb hub plugged in to my macbook all the time?
Yes, you can leave the USB hub connected without issues for your MacBook. Just keep in mind that some of the devices you plug in to the hub will draw power from the Mac; if you're running on battery power, this will lessen your time between needing charges.
Sep 24, 2013 | Apple Cinema Display Flat Panel Monitor...
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Side usb ports not working now. they were this morning. back ports are operable. I tried my flash drive and wireless Logitech mouse M305 (mouse had been long installed there). There was no tumble or...
Ok well maybe the drivers just got mixed up,try this below, remember you will have to reinstall ALL USB devices again, so have all the drivers ready, I put all my drivers in a driver directory, so whenever i must reinstall, i have the drivers for all my devices at hand, under one directory.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
However often when a USB dongle device is jostled in and out, it can. and does, "Spike' the USB port, and sometimes it will "Blow" the USB inline protection fuses, on the motherboard. This is evidenced by NO Voltage at all on the port. If this is so, then you need to get this repaired. As a workarround, one can hookup a USB Hub, and connect all else up through that.
Nov 09, 2010 | Toshiba Satellite A45-S150 Notebook
PS3 controller has 4 red flashing. Console has green, display OK. No response from PS button with USB connect or not. 5volt on 1 USB is on and off, other OK Help please
4 flashing means it has a dead battery leave it plugged in with the system on. if that doesnt work change the cable reconnect and leave it to charge good luck
Sep 09, 2010 | Sony Playstation 3 (PS3) Console
Ipod touch stuck on itunes logo when plugged into computer via usb lead itunes doesnt recognise it
ok this happened to me before. this is what you do.
1. plug ipod into another computer (possibley a freinds)
2. download the latest ipod software
3. set up as new ipod (your ipod should work like the very first time you used it)
4. plug back into your computer and sync with your itunes
5. ipod should be back to normal
good luck. leave a comment if this does not work please
Aug 25, 2010 | Apple iPod touch
CHARGING MY GARMAN GPE C330. DO I LEAVE THE GARMAN ON OR OFF WHEN CHARGING . THE BATTERY WAS DEAD ON MY WAY BACK FROM MY LAST TRIP.IT WAS OK GOING UP I HAD IT PLUGGED IN TO CIG LIGHTER BUT GARMAN SEND...
Disconnect from cigar lighter and connect to the USB port of your computer or any AC adapter over night. By morning the battery will have recharged and be ready for use. This seems to happen with the GPS is left connected to a vehicle's cigar lighter for an extended period of time. You can do this USB / AC adapter recharge procedure as often as needed.
I hope this helps!
Jun 08, 2010 | Garmin nuvi 250W GPS Receiver
When should serpentine belt and plug wires be changed? I have a low mileage car 40,000, should I change the belts and plug wires?
no just inspect if belt appears ok leave alone ,as for the plug leads again the same if it runs ok leave well alone ,just the timing belt because they can dry out with age
Apr 04, 2010 | 2000 Mercury Sable
My Book green light continuously blinks and is not recognized by
mine does the same thing ..they must be unplugged from your power to turn it off.if you leave the usb plugged in its ok ..just unplug the power from the wall socket
Jun 23, 2009 | Western Digital 320GB MyBook External USB...
Samsung YP-U3 mp3 won't turn on!! help please
try pressing the menu button and the play button at the same time
Jan 13, 2009 | Samsung YP-U3 MP3 Player
Frozen on Making Playlist
hi, did you get your problem solved? I just bought it today, and had the exact problem.
Apr 25, 2008 | Insignia Kix MP3 Player
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
