Question about Xerox WorkCentre M20i All-In-One Laser Printer
I have a Xerox Phaser 6180MFP unit. When faxing from the PC and there is a no answer, the error code 035-701 appears on the printer and hangs it up until you press ok. Is there a way to suppress the display of the error so the printer continues to process? I could not find it in the manual.
4 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Phaser 8200N hangs on warmup
Did someone replace the entire heater or just the lamps?
It is important that the wattage of the lamps were 150 watts each, and that the ends of the contacts were cleaned well. Does it shut off during a run and warm up?
I have noticed with those assemblies that you have to clean the contacts well when replacing those.
If you are not faulting out, then they are working, but not at the level they should be.
The drum thermistor may also need to be replaced. That detects the temperature of the drum and would cause it to warm up slower then normal, but also, when those fail you normally get a fault code.
Just seems odd, though. It keeps running through my mind that the heaters are just not comming on to full brilliance, and that would mean for one reason or another, lack of proper wattage.
Could you somehow have gotten lamps or a heater rated at 220 volts and not 120 volts?
Posted on Mar 07, 2008
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
  • 304 Answers
SOURCE: I have error on my
116-324: Controller Error (Illegal Exception)
To access Service Mode, press Up and Down Arrows at power ON.
Go to EEPROM Test
EEPROM Test
? Start
? Processing
? Check OK
Performs write/read/verification of the test patterns (0xff, 0xaa, 0x55, and 0x00) on one byte at every 0x400 from the first address of EEPROM.
Posted on Sep 14, 2011
Fax confirmation sheet on a Xerox Phaser 6180MFP
Not quite sure what you mean here, it can be switched either on or off within the internal settings. Normally the default would be off in a large office due to wasted pages, but in "print for pay" a customer has a receipt that the fax had arrived at it's destination.
Good luck.
Jun 13, 2014 | Xerox Phaser 6180N Laser Printer
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
ERROR 016-782 XEROX 6180MFP with windows7.
While there is no specific download for Win7 for this KB, you could try one of the others:
http://support.microsoft.com/kb/916846
Sep 21, 2011 | Xerox Phaser 6180N Laser Printer
Phaser 6180MFP has error code 133-290 how to correct, and what is it.
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Oct 04, 2010 | Xerox 6180MFP/N Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Oct 09, 2009 | Xerox 6180MFP/D Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
513 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
