Acer Aspire 9805WKHi Notebook Logo
Anonymous Posted on Aug 24, 2010
My Acer Aspire 9805WKHi wont turn on past the main acer start-up screen after my battery died. I didn't realize it wasn't plugged into the ac adapter so it was running only on battery.
  • Anonymous Aug 24, 2010
    I tried that and the same problem still persists, The computer starts up with the acer screen and then just goes black.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Aug 24, 2010
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
7509
Points
68
Try taking out the battery and just plug in the ac adapter and see if it powers on that way. If it does use it that way for about 30 minutes then shut down. Put the battery back in, and keep it plugged in and wait about 30 minutes before you turn it on. This should refresh the battery enough to start charging.
    Can you get into the bios at all?
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
My acer aspire will charge a battery but wont power up when i plug in the ac adapter the battery light will come on but no ac light will not power up in battery or ac
Does the laptop come on when you plug in the mains and take out the battery? If it doesn't then it could be a faulty power switch.
I HAVE A ACER ASPIRE 5100 & WHEN I TURN IT ON THE SCREEN IS BLACK & WONT DO ANYTHING. THEN ABOUT ONCE EVERY SO OFTEN IT DOES BOOT UP BUT TELLS ME THAT I HAVE TO REINSTALL WINDOWS & WHEN I GOT...
You might have a bad AC adapter, bad Battery or bad motherboard.
1.) AC Adapter about $60
2.) Battery around $100.00
3.) Motherboard around ?
I would start with adapter first. If you see that you have to go to Number 2 or 3. You might to just get a whole Laptop, if this one is not still under warrenty.
1helpful
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Troubleshooting Acer Aspire 9805WKHi PC Notebook
TRY TO REFORMAT YOU LAPTOP.. THEN OBSERVE IT IF THE SAME PROBLEM. CHANGE YOU RAM OR HDD MAYBE SOME BAD SECTOR THAT WHY CAN'T CONTENIU THE OPERATIONS
THANKS
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
