Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Ive just bought a black and decker 40cm electric chainsaw, and on putting it together instuctions say after ten mins adjust the chain, thats going to be difficult because the tensioner is already at maximum, and the chain isnt that tight... i bought it from b and q ,,, the box was sealed, but the chain doesnt seem right!!! what do you think? regards
    Champion:
  • 313 Answers
Take your unit to where you purchase for replacement. dont forget you receipt
Posted on May 29, 2008
I have a replacement chain for a electric 40cm Bosch chain saw but it can't get the new one on as the chain tensioner will not go back far enough does it ever get blocked and should I take the cover off...
Take the cover off, Take the bar off. Clean it out. Put the chain around the sprocket. Put the bar on. Put the chain around the bar. Tighten the chain a bit. Put the cover on. Tighten the chain.
Feb 22, 2015 | Bosch Saw Chain for AKE 40 / 40-17 / 40-18...
How to repair a chainsaw
your clutch springs are weak. replace springs or clutch assembly
Jul 17, 2014 | Black and Decker USA BLACK & DECKER...
Use maintain chainsaw
if your question is "best way to care and use a chainsaw"
care: well that's slightly different for a gas model vs an electric model
gas models should not be stored for longer than a week with fuel in it's system (tank,lines,carb) as the gas will evaporate and cause deposits to form (hard) and clogg up the small ports in there
electric models, should be inspected for cuts to cord and general safety ck over saw to make sure it's not going to shock you
just because they show it on tv , chain saws are not for cutting in water or around water , one its not good for the metals the saw is made from and two if water gets inside the motor (gas or electric) its no longer going to run anymore
always keep your chain oiler full of bar oil (not motor oil) and top off every 30 min of use
and sharp chains cut cooler and longer than dull chains , lot less effort too
Jan 08, 2014 | Black & Decker Garden
What type of bar chain oil should I use
For spring/summer use, you can use Motomaster ("spring/summer") or Stihl "medium" chain oil. If you use in very cold winter condition, you need thinner oil, specifically made for it.
Feb 02, 2013 | Black and Decker USA BLACK & DECKER...
I have a 1600w electric black & decker chainsaw recently purchased that simply takes forever to cut the smallest of logs. Is this the norm?
Hi there Bugs,
Definitely not the norm. I'm guessing that although it was recently purchased, it was used?
It will either need a new chain or have the old one professionally sharpened. You didn't mention bar size, but a new chain should be between $18-30.00.
A less expensive alternative would be a small engine repair shop that services chainsaws. Most also have reconditioned chains for sale.
Eight days ago I picked up a 19" bar banana bar and used chain for $15.00 total to finish some oak. It Rocks.
Try the chain change. Difference? Night and Day.
Best regards
Mike
Jul 30, 2010 | Black & Decker Garden
Instructions on black and decker gk1635t electric chainsaw of how the chain tensioner is adjusted and set up initialy
Your OM follows:
http://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gk1630t,%201640t_gb_md09.pdf
See page 10 please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Black & Decker Garden
How do you adjust the tension in the black and decker 16 inch electric chain saw. The chain is too loose...
UNPLUG THE CHAINSAW. if it's got a bolt or two on the right hand side loosen them, then turn the adjuster screw next to the bar until you have about 1/4 inch slack in the chain. tighten nut/nuts. if it's got tool-less adjustment loosen the cover bolt, turn the tensioner, tighten the cover bolt.
Mar 28, 2010 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
87 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
