Question about Kenmore Washing Machines
I have a series 80 top load washer will fill to level selected but wont do anything after that. The only thing the washer does is fill to specfied warter level and then stops. Wont do anything after that
  • 530 Answers
You have a bad lid switch
let me know if this helps or if you need more instructions
Posted on Aug 24, 2010
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
My Sears series 80 washer fills till it is overflowing and doesnt shut off water flow, it was overflowing onto floor this morning, it is full to the rim now, and wont drain or do anything when it is turned...
The usual arrangement is there are 2 electrical water inlet valves, one for Hot and 1 for Cold. These valves are turned on by the timer, and remain on until the water level switch turns them on, and allows the washer to then run. It sounds like this water level switch is bad. This switch should be in the panel above the top of the washer, and has a rubber/plastic tube that goes toward the washer drum. It is also possible that the rubber tube is off or blocked. (if the water inlet valve is stuck open, turning the washer off will NOT stop the water).
Good Luck,
Bill
Aug 17, 2012 | Kenmore 23822 Top Load Washer
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
My washer wont stop filling up.cold and warm work but it doest know when to stop filling up hot doesn't work at all.please help my water bill was really high this month it a kenmore 80 series...
There is a defect or , malfunction within the Water fill level pressure switch. this switch will cost about 35 dollars and, it should be replaced asap.it has failed.
Replacing the
Water fill level pressure switch, will fix your issue.
Jun 16, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 80 series washer will not stop filling up
one of three things,inlet water valve bad,water level hose came loose or water level switch is bad,check all tree and let me know-mike
Apr 14, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
