Question about Electric Garden
We have a Pressure washer 2600 PSI it is hooked up to the water line and we have a bucket of mix of 50% bleach and 50% water there is no suction coming from the line into the washer to mix with the water Why?
    Problem Solver:
  • 18 Answers
You need a soap nozzle to lower the psi is call downstream injection.
Posted on Aug 25, 2010
What kind of soap do I need to use?
I suppose that would be dependent upon what you would be cleaning eh?
If moss on white siding use a bleach solution
Otherwise for general cleaning I prefer "simple green" -- you may cut it up to ten times with water....
Best regards
Ck
Aug 18, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
What kind of soap do i use and do i use it strait or mix with water i have a 2600 just a hose i think is for the soap
most solutions are sold to be used as is , place the tube from the washer into the cleaning solution as you spray it will be mixed with the spray water . the kind of cleaner depends on what you are cleaning . you can buy cleaner for decks or cars or house etc.
May 15, 2011 | Honda 2500 PSI Gas Pressure Washer
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
The hot water just trickles out of the hot water taps, I've checked & cleaned the tempering valves, mains water pressure is fine, is the cylinder scaled or blocked
Something is blocked. Turn off water to heater disconnect outlet and attach a waterheater flex connector to tank outlet bend other end into bucket. turn on water briefly - water should blast into bucket.
If not:>>>>>>>>>> disconnect water heater inlet -you may find part of the flex washer stuck into the inlet nipple. Or dip tube may have disintegrated and be plugging outlet nipple, if you have the energy saving nipples the ball can jam debris in the nipple.
If water does blast into bucket >>>>>>>>>>>> Then the problem is farther down the line, maybe bad mixing valve. disconnect mixing valve outlet and use a garden hose to backflush through mixing valve with bucket under hot pipe disconnected from water heater. If flow through valve is restricted, replace valve.
Jan 01, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
hook up water hose dose not pump water?
May 26, 2009 | Garden
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
120 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
Mike
Are you an Electric Garden Expert? Answer questions, earn points and help others
