I need a replacement for a Trane thermostat model # X13530073-12. Thank you
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: need wiring help for replacing
I am not sure of what help you need on it but here are the most common wiring on a stat
W= heat
C=Common (24V)
R=Hot (24V)
G= Fan
RC=Hot (24v for Cooling)
RH= Hot (24v for Heat)
O= Reversing Valve (Heat Pumps Only)
Hope this helps
Posted on May 11, 2008
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
  • 35 Answers
SOURCE: trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Posted on Jun 10, 2011
I have a Trane model BLU080F924B1 gas furnace that will not shut down. Replaced thermostat and problem continues. Burner still runs even with thermostat switch in the off position.
probably not a thermostat problem but a gas control solenoid or stuck valve
call a gas fitter for a proper diagnosis and quote
Oct 29, 2016 | Heating & Cooling
I have a Trane 3AAT80B1A1 thermostat that I'm replacing with a Honeywell RTHL 3550D. Is it possible to do this myself or will I need to have an electrician come out?
The easiest way to be certain the wires get connected is to cut the wires close to the screw without loosening the screw. That way the color of the wire can be seen on the correct terminal without mixing them up.
Feb 24, 2013 | Heating & Cooling
Had my Trane XE 70 serviced and was told I need a new ignitor module. Then was told it can't be ordered and is no longer available. Also, that no generic replacement will work with my unit. Model number...
all furnaces by national code must be 80% eff or higher whitch negated the productions of th replacement parts for such units. I tried to find a burner for that model w no luck
Jan 22, 2011 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need wiring for honeywell pro 3000 in trane xe1200
May 16, 2009 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
357 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
