Question about Adobe Acrobat 6.0 Professional for PC
When i want to open a file it stops 3 times with error message, each time by pressing "ok" it continues to the next stage after pressing "ok" for the 3rd time it opens the file First Error message says" THERE WAS AN ERROR WHILE LOADING THE PLUG-IN ' HTML 2 PDF.api ' , The plug- in failed to initialize . 2nd and 3rd message are simillar excep the middle part of the message which are as follows: 2 - Thank you very much
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 15 Answers
Error While Loading Plugin Html2pdf.api may be caused by windows system files damage.
Call on Adobe support number they will help you troubleshoot some common error messages related to Error While Loading Plugin Html2pdf.api that you may receive.
Adobe Customer Support Number
Posted on Jul 12, 2017
sandrew
  • 2961 Answers
SOURCE: Installing error code -106
what this suggests is that the files cannot be transfered to the hard drive because of either you havent the latest version of .net http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en, or you are low on hard drive space or afaulty disc. download from the above link first, then if still not installing try copying all the installation files across to your pc and try again, but check you have enough hard drive space.
Posted on Aug 24, 2007
SOURCE: Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Posted on Nov 26, 2007
  • 43 Answers
SOURCE: unable to download pdf file
Uninstall all Adobe software what ever version you have, than go to start>search>all files and folders, select local hard drive if it is not, than click more advanced options, select first three things in the list and than type adobe in All or parts of the file name. When it finds folders and files select them all and press DELETE. Than empty your Recycle Bean and restart your computer once it is up download new Adobe installation file and install it again. I know that this is pain but you will have to get rid of all damaged files used by adobe reader.
Posted on Feb 04, 2008
pagemker
Posted on May 02, 2008
SOURCE: java install 1101 error
umm u know..?
its kinda stuped i cant even play runescape any more a mmorpg game it has more than 80mill player really and now i cant download the latest version i tryed to delete the older 1 but now i have a seriouse problem i cantdownload the old 1 even!
so stiped but i think i have a sulotion
buy a new pc becouse ur pc may be old and kinda dum
Posted on Aug 13, 2008
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
OXC 18a0001 error message
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Jul 06, 2011 | HP Photosmart C7180 All-In-One InkJet...
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
May 06, 2011 | HP Photosmart D7460 Printer
My HP all in one printer C7100 has an error message that says there is an ink system failure error 0xc18a0201 I don't find any solution What should I do. It won't fax either.
Try this solution.
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
1. Press and release the right arrow button until the display says "System Configuration Menu".
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
May 04, 2011 | HP - HP Photosmart 8250 printer
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error:oxc18a0206
1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Dec 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
Print unable 46
There are probable two causes, a mechanical problem or a foreign object such as a paper clip or ripped paper is in the machine.
You need to open the scanner cover and remove any foreign objects inside the machine.
If the error message continues, disconnect the machine from the power for several minutes and then reconnect it.
Still if your problem continues then you need to reset the purge counter.
  • Enter machine maintenance mode . Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
  • Press the Menu/Set and Black Start keys. Next press the “up to arrow” key four times to enter the maintenance mode.
  • Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
  • Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
  • Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
  • Press the Stop/Exit key to return to the initial stage of the maintenance mode.
  • Press the 9 key twice to return to the standby state.
Hope this helps .
Do rate the solution .
Shane
Dec 06, 2009 | Brother Professional MFC-5490CN...
I HAVE AN ERROR MESSAGE FOR C7280, OXC18A0206
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Adobe Acrobat 6.0 Professional for PC Logo
41 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
