Question about Toshiba e-Studio 161 Copier Copier
When I switch on the copier display H and than 4.. please solve my problem with thanks.
  • 86 Answers
Call sercice and tell them that there is a problem with the Heat roller low temperature detection.
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150C° after 55sec from the start of warming
up.
When the warming up complete temperature is
not reached in 30sec from reaching 150C°.
100C° after 20sec from ready start.
145C° when printing."
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check and remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
Posted on May 05, 2008
MY TOSHIBA E-STUDIO 452 HAS A MESSAGE OF INSTALL NEW TONER AND I HAVE INSTALL A NEW TONER ALREADY
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
May 18, 2012 | Toshiba E-Studio 3511 Color Copier
TOSHIBA E-STUDIO 161 error code show mw H and 4
How are you this is jack my id jack_pak@hotmail.com
your copier toshiba 161 show H...4
Dear, Follow the procedure.... press C(CLEAR) BUTON+ PHOTO BUTON+C BUTON+PHOTO BUTON..... Your copier enter special mode
Then you press 14 and start key.... copier ...ok
PLEASE VOTE ME
Thanks,
Best Regards,
Aug 31, 2010 | Toshiba e-Studio 161 Copier Copier
We want error problem ofter switching blinking red print key without warming and function 4 delate error not any function by copier
First you need to let us know what the error code is displayed on the display screen. With that there is a starting spot, then will be able to move closer to solving the problem...
Oct 10, 2009 | Canon NP 6050 Copier
HP Laser Jet 4 with an unreadable screen
It may be a coded error message. See here.
Otherwise, try following these instructions to reset the language options.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | HP LaserJet 5550 Printer
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
May 29, 2009 | Canon ImageRUNNER 330s Copier
F and 5 code
F means exposure lamp
Check either lamp or may be more dust???
Thenks
Jul 20, 2008 | Toshiba e-Studio 161 Copier Copier
Display H and than 4.. please solve my problem with thanks.
call sercice and tell them that there is a problem with the Heat roller low temperature detection.
up.
Check and remedy
operation.
PWB.
May 06, 2008 | Toshiba e-Studio 161 Copier Copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
If the machine dies enter code 14 then press start, the machine will reboot normal, if the problem persist, the fuser unit needs replacement
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba estudio 161 copier
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
Toshiba e-Studio 161 Copier Copier Logo
88 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
