Question about Kenmore 51692 / 51694 / 51699 Side by Side Refrigerator
Stops cooling and freezing then restarts a few hous later
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
I need to stop hot water supply for 10mins to fit water stop **** to sink tap. Does RA 28c need to be shut down and restarted later or can the hot water temp be temporarily set to say 10deg C ?
Turn off the heating ,let water cool down then use a freezeing pack to freeze section of pipe you intend to insert the stop valve, you can get a freeze pack from a plumbers merchant .
Jan 21, 2018 | Miscellaneous
Hoover a class fridge freezer both not working
Feel the top of the compressor and tell me if it is too hot to keep your hand on top. Model number is?
Appliance 911 Sea Breeze
Oct 13, 2015 | Hoover Refrigerators
Kenmore refrigerator freezer stopped freezing and cooling then several hours later started working again ?
Look at what time the defrost timer is set to. It may just be as simple as resetting the time or you may need to replace it .
Aug 04, 2014 | Refrigerators
Picture freeze,long tme to restart does it again
Unless you have good / fast access to the Internet (or wireless or 4G network), it may take a long time to download a movie to your device. If the speed of download is slower than the speed of the play, the picture freezes ... essentially, it is waiting for the completion of the download for the next few frames (of the movie). That is why the picture freeze .... and it will start again after sufficient data has been download to continue / start playing (the movie) again.
Apr 30, 2013 | Cricket Wireless Cricket Crosswave WiFi...
My dryer stops running after a few minutes. The fuse has been replaced and the repair man replaced the motor and it stills runs for a few minutes then stops. HELP!
Did you clean it out too? Check the venting for clog behind dryer or at the vent cap? Is the house breaker clicking off? Is the dryer motor humming or just stopping? Does it restart every time you try or do you have to let it cool down for a bit to restart? Need more info to be sure. You may have a bad sensor, but you'll need a repairman to check that.
May 14, 2010 | Maytag Dryers
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
GE refrigerater stops cooling/freezing and restarts?
maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Jun 21, 2009 | GE Refrigerators
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
When starting, hear a noise like if the motor has problem rolling. The dryer works but stops during the cycle. Smeling heating after a while. And few minutes later, restarts and works, and stops...
sounds like your motor is on the way out. Hard to start-- when it does go it eventually overheats---- wont restart till cools down. sounds like a motor going bad
Mar 07, 2008 | Dryers
Refrigerators Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
