Question about Microwave Ovens
Need a rubber seal for inner lid on CW-PZC30 elec air pot.
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
I want to report a design flaw on your "Stay or Go Slow Cooker, 6qt." The black pllastic hold down tabs on the lid have both broken off. When I tried to clamp the lid down, both tabs broke off...
This is a website that will help you fix things, but it is not affiliated with any product and no products are actually sold here. The only thing that is sold is advice regarding how to best fix products that have failed.
To get a better response to your issue, you need to contact Hamilton Beach directly through their customer service department.
Click here
This link will take you directly to their customer service page.
heatman101
Aug 22, 2011 | Hamilton Beach Microwave Ovens
My preassure cooker is spewing out water off the top, i think the problem is the rubber lining of the rim
If it is coming out between the lid and the body then it is the rubber seal...if it is coming out the top vent then the pressure is too high and the vent is keeping it from blowing up... turn the heat down a bit...
heatman101
Aug 04, 2011 | Microwave Ovens
Hi my sf 80hj washing machine leak below ( rotating shaft) sos thank
A rubber gasket (seal) must be replaced. This seal connects the bottom of the tub to the rotating shaft (Agitator shaft).
A variety of factors determine how long these rubber gaskets last befroe they start cracking.
The seal is available from most appliance parts stores (local and on-line). The trouble is replacing it, it take about 2 hours for an amature and some major disassembly. Removing the agitator, the inner tub (the one that spins after rinse cycle), and some shaft pieces.
Cost for a repair technician will be about $150 to 200 (guess only - I am not sure about the rates in your town).
Good luck.
May 23, 2011 | Microwave Ovens
I am looking for a rival crock pot lid @3755
Try this site. They have quite a few replacement parts/lids. They most likely have a universal lid you could use and none of them seem too expensive.
http://www.marbeck.com/categories/KITCHEN/Crock-%26-Slow-Cooker-Parts/Rival-Crock-Pot-and-Slow-Cooker-Parts/
May 03, 2011 | Microwave Ovens
I need a replacement lid for rival crock pot scvs601, sc43 slow cooker. Any suggestions?
You can order new lid w/ hinge for $15 from manufacturer (http://www.crock-pot.com/customerservice.aspx) or I have been told they'll send it for free if you contact them (https://secure.crock-pot.com/contactus.aspx) and say the hinge broke. Might depend how old your unit is.
Oct 05, 2010 | Microwave Ovens
I have a Monier crock pot which is approx. 30 years old and still working well but the plastic lid has a crack in it. Is it possible to obtain a new lid
Contact Monier, they may have a replacement.
If not take the plastic lid with you and go shopping, look for glass lids on pots and pans that matches the shape of your plastic lid.
Oct 02, 2010 | Microwave Ovens
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
Dishwasher is leaking on the right hand side when cycle is running. Seal is not broke and everything seems fine. Any suggestions?
The problem could STILL be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly against the inner door facing, or food particles and grime get caught between the inner door and seal and leave small air gaps.
The following link explains some of the common causes of dishwasher leaks and what you can do to prevent them:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
This is a very simple repair that you can perform yourself without the assistance of a repairman, and it usually does not cost much. The average price of a door gasket ranges from $25 to $45 depending on model. If you have questions, or require additional assistance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 15, 2010 | Microwave Ovens
Damaged inner seal tape on whirlpool microwave door window
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2008 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
