Question about Pioneer VSX-108
Had a blown fuse I replaced it and now sfc light is lit but no other digital display
I used my sharp R-1821 convection microwave that night it did not work. outlet is lit up but display does not come on. Why?
More than likely it will be one of the three door switches. Also check the internal fuse in the unit. The fuse if blown is just a symptom, not the problem. It doesn't always blow out but the right combination of switches bad will take it out.
Dec 03, 2014 | Sharp Microwave Ovens
Battery Load Test lights do not function
Someone on youtube suggested changing the fuse.
http://www.youtube.com/watch?v=jUuIANsxVtI
Dec 23, 2012 | Innova Equus Products 3320, Auto Ranging...
Can't see digital indicators in day light to dim
Your back-lit display light is either burnt out or the fuse is blown. It may be a more serious problem that needs expert attention. i.e. a mechanic
There could be a circuit board that controls the back light that has gone bad like I had with an LCD monitor once.
Sep 12, 2012 | 1994 Ford Aerostar Extended
2002 Yamaha R1 headlights not working and turn signals. Bike starts no problem. Dash displays turns signals icon lit and high beam icon on but lights. I checked all fuses on the left had side no fuses...
my friend you have a short in your wiring harness. The best way to do a mini check is take your fairings off and start jiggling wires. Usually, if there is a short the lights and/or blinkers will blink.....otherwise your bulbs could be blown. If the harness is shorted go to your dealer or someone capable of fixing the problem( you probably can do it) hope this helps you...good luck!!
Mar 17, 2011 | 2002 Yamaha YZF-R1
Digital odometer below the speedo has stopped being lit up.now i can hardly see it. i checked the fuses and cant see any blown??loose earth wire maybe?
Hi hairymcchevy,
Yes, it could be a loose wire, but more likely, if no fuses are blown and the rest of the dash panel is lit, it is a bulb inside the dashboard/odometer. Most of the digital dashes I have seen are lit through the clear plastic housing behind the matte finished masks. This is not exactly an easy fix, but it can be done.
you need to take the dash top off, remove the instrument panel, and check the bulbs in or behind it, to see if any of them are blown. It may save you a lot of work chasing down a loose/shorting wire.
Sky_Signal
Oct 30, 2010 | Audi A4 Cars & Trucks
Air conditioner stopped working no dash light for i amwondering if there is a fuse that might need replaced as thee blower fan does not engage, andf the lights that usually are there and lit are not lit.
Yes there is a fuse located in the fuse box ...This sounds like it is definetely the problem ...If no fuse is blown have the a/c relay checked...
Jun 23, 2010 | 2000 Oldsmobile Alero
After replacing the battery and alternator in my 1984 Jeep Cherokee, the battery light on the dash stays lit. What could this indicate?
GET A DIGITAL VOLT METER CHECK BATTERY VOLTAGE IT SHOULD BE 13.5 VOLTS TO 14.5 VOLTS WITH ENGINE RUNNING.IF NOT.ALTERNATOR FAULTY.LOOK FOR A BLOWN ALTERNATOR FUSE.AND CHECK FOR DAMAGE ALTERNATOR WIRES.
Jan 10, 2010 | 1984 Jeep Cherokee
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Pioneer VSX-108 Logo
26 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
