Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Usb 2.0 error
I have connected seagate free agent 500gb hard disc to my laptop hp dv2119tx through the usb port.
both the devices are usb 2 compatible, yet i dnt get the desired speed of 480mbps while data transfer or nething.
same problem is with sandisk 2gb pen drive also.
the error is usually, " the device is connected to a low speed port. connect to higher speed port, for better results"
pls help me to use the full potential of usb 2.0
    Scholar:
  • 144 Answers
Did you connect directly to your laptop or you connected via external USB Hub?? Your notebook model should support USB 2.0 ...so it should not face the problem you post..unless you're not connecting it directly.
takecare.
Posted on May 05, 2008
Windows has stopped this device because it has reported problems. Code 43 This message pops up in when i plug in my SeaGate Free Agent GoFlex hard disk.
Try this as a possible fix.
This trick can quickly fix many mysterious hardware failures
The other thing I've heard of happening is a few of the USB 3.0 ports having problems with USB 2.0 equipment. I know it should be back compatible, but Windows can have problems. Try another USB port to see if that helps.
Does the SeaGate cable have 1 or 2 connections to the computer? Unfortunately, most external hard drives need to connect to 2 USB ports to get enough power.
I just looked up this problem on Seagate's website, and they pretty much come up with the same answers. Uninstall and re-install the USB drivers with the SeaGate connected. Or use other USB ports. The other suggestions they have don't make sense, if you can't talk to the thing, how do you run Seatools or checkdisk?
Fixya doesn't allow me to put in another link at this point, so you'll have to copy and drop this into your address bar.
http://knowledge.seagate.com/ka030000000tmkPAAQ
Here's another write-up on fixing the code 43, I wouldn't do number 6.Update BIOS though, USB is working fine with everything else, it's NOT the BIOS that's having a problem.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
Jul 26, 2016 | Seagate 500GB FreeAgent GoFlex Hard Drive
My extenal Hard disk seagate free agent 500 gb is not detected by my laptop
try all usb inputs. if it still isn't try another computer. It should be found. Make sure it is plugged in just right or wiggle to see if it finds it. if not then maybe the hard drive is 3.0 usb and the computer is 2.0 just some thoughts
Sep 15, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
Seagate 500GB FREEAGENT DESKTOP 7200RPM EXTERNAL USB 20 HARD DRIVE 16MB it just stoped working in the middle of the movie, complete blackout, tryed conect to another PC nothing came up, what it could be...
Try this:
1. Turn off the power supply to the hard drive.
2. Turn off your PC/laptop.
3. Connect the hard drive to the PC/laptop.
4. Turn on both devices.
It worked with mine.
You could also try installing Seagate Manager which can check for errors on the drive.
Jun 10, 2011 | Seagate 500GB FREEAGENT DESKTOP 7200RPM...
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
May 06, 2010 | Seagate Free Agent Go Small 12 GB USB...
Cannot read
It sounds almost like 2 things are happening,
1. The drive itself it going out or the board inside that is connected to the drive is bad.
2. or the drive is not getting enough power through the USB ports (or too much maybe?)
I have only encountered the beeping issue on my free agent 160GB when it was not getting enough power to spin up the platters.
If you still have warranty on it. I would HIGHLY recommend you call western digital about it.
Mar 20, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Freeagent
Turn off computer.  Unplug hard drive from computer port.  Turn on.  uninstall from Add/Remove Hardware in Control Panel.  Reboot computer.  Plug in external hard drive.  Verify Full System functionality in Control Panel, System, Hardware, Device manager.  If nothing is expanded all IS functional.
James Mac
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
