Question about Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower
Front wheels are out of line - Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower
  • 1 more comment
  • gdavis3830 Aug 24, 2010
    there is no adjustment for front wheels
    there is no adjustment nut
    i have replaces both steering rods they are the same length as wll as the axle assembly
  • 15,935 Answers
Look closely at the front suspension, and you will see to in and toe out adjustments. There is a linkage tie-rid to adjust for wither wheel.
Thanks!!
Posted on Aug 24, 2010
    Top Expert:
  • Husqvarna Master
  • 80,417 Answers
Loosen the tie rod adjuster nuts or collars at the rod to each wheel and adjust the wheels so they measure the same from front to back of tire plus or minus 1/4", that is good enough for a riding mower, check that wheel is centered, the wheel can be centered by turning the tie rods in the opposite direction the wheel is off center equal amounts, then recheck the from to back of tire alignment again..
    President:
  • 986 Answers
Something has wear, or it is bent somewere for it to be out of line,,but there is a solition for both,if it has been bent it can be straighten if its worn replace parts,and take a tape measure in front of the wheels and behind the wheels and adjust until you have a straight line,
  • 11,896 Answers
There is an adjustment nut on the steering linkage or shafts. Adjust them so the wheel are straight.
  • Nate Stansfield
    Nate Stansfield Aug 25, 2010
    Do you have a model number for this? I will try to look up a manual so I will be able to tell you how it's done. Your must be a little different than the others that have the adjustment.
Is there two brake lines to rear
rear brakes has two brake lines from mastercylinder to both rear wheels cylinders. front brakes has two brake lines from mastercylinder to front brake calipers for each front wheel.
May 07, 2013 | Cars & Trucks
08 f150 4x4 on front end only one side is disengaging when in 2 wheel drive. The problem is when engaged into 4x4 wheel drive the front drive line spins and both sides engage but only the back wheels spin...
If I read this correctly ( which I might not have, bit early for me ), the front drive shaft will engage ( from the transfer case ) but the front wheels are not engaged ?
If so, sounds like either the vacuum from the IWE ( Integrated Wheel End ) is not being released, or the IWEs have had an issue with part vacuum ( damage vacuum lines ) and the IWE gear is rounded off.
If you pull the vacuum lines at the IWEs ( there are 2 lines, 1 is the vacuum line, the other is the vent tube that routes up into the engine compartment and is not attached to anything ), the front wheel should engage ( might need a 5 * turn to mesh the gears ). With the vacuum lines off, jack up the front axle ( take precautions, chock the rear wheels, parking brake, jack stands, etc ) see if the front wheels are engaged ( turning one wheel should turn the other ). The option is to do this after the truck has sat over night, and the vacuum has been released out of the vacuum reservoir.
If the wheels turn correctly ( engaged ) I would think the contact plates in the transfer case are not making contact. Good starting point for this is the connector on the side of the transfer case, some times this gets gummed up, and the pins do not make good contact. The contact plates in the transfer case are used for a few things, one of them is to signal the IWE solenoids to release vacuum to the IWEs.
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vacuum is removed the spring engages the IWE.
Here is a black diagram of the IWE vacuum system
Feb 05, 2011 | 2004 Ford F150
My 4 wheel drive will not engage, could it be a blown fuse?
Is the system ESOF ( Electronic Shift On the Fly ) or MSOF ( Mechanical Shift On the Fly ) ?
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vac is removed the spring engages the IWE.
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
- If the front drive shaft does not turn :
Shut of the truck ( still jacked up, and supported ) remove the vac lines from the IWE. The spring should push the gears in, without the vac line on.
Check the vent line ( tube that is routed into the engine compartment with nothing attached to it ), for blockages.
If the vent line is clear, and with the vac lines off the IWE should be engaged ( both front wheels locked ).
If they lock, the problem is with the IWE solenoid not shutting off vacuum to the IWEs. There is a TSB on the 2004-2006 IWE solenoids, a newer revision has been made, and used from 2007 and newer MYs.
Here is a block diagram of the IWE system
Dec 17, 2010 | 2005 Ford F-150
2004 f150, shift into 4 wheel,manual shift in floor, light comes on but dosent go into gear, any suggestions?
Dec 15, 2010 | 2005 Ford F-150
2004 ford f150 4 wheel high will not engage 4 low will has manual shift
Nov 28, 2010 | 2004 Ford F150
1968 ford mustang brake line diagram
It's pretty simple. The front line from the mastercylinder should go into a tee, then from the tee to each front wheel. The rear the same way. No proportioning valve is needed with 4-wheel discs.
Feb 25, 2010 | Ford Mustang Cars & Trucks
2005 ford f-150...4 wheel drive will not
Dec 19, 2009 | 2005 Ford F-150
Can you straighten torqued front forks on a 2002 Yamaha TTR 125 L
you should be able to saporrt bike so front wheel is off the ground   then take a marker and put lines around where the forks meet the triple trees that hold them in place their should be some allen head bolts that u can loosen on front of the triple clamps  once these are loose you should be able  to move the forks back to strait again in line with the handle bars just line the lines up that u put on them earlier and tighten the allen bolts back up    also  when making the lines  make them from left  to right so marker is touching both fork tube and triple clamp   this is only so you get can keep them the same ride hight as before
Feb 15, 2009 | 2002 Yamaha TT-R 125 L
Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower Logo
669 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
