Question about Dryers
When I tried to start dryer I hear a lite noise in the area of timer but dryer wount start. Could it be timer malfunction or something else?
  • 1,543 Answers
Very un-likely that you have a timer problem. Check for broken belt (switch on tension assembly cuts power to motor) a door switch, or possibly a non-resettable drum thermostat out, due to a long or restricted vent.
Posted on Aug 24, 2010
My dryer is not turning on..I hear a click as though it is trying to but nothing happens
I'm guessing your hearing the timer making noise...if its the timer making noise you need a multi-meter to check the thermal fuse and links.
There is a long fuse that can go bad and cause the motor not to start. The thermal fuse is behind the back panel. remove panel and check fuse's
May 20, 2010 | Whirlpool WED5900S Electric Dryer
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Dryer does not start. if you push on the start button you can hear a small hum from the area of the timer, otherwise nothing. door switch seems to be working
one  make sure you advance the timer into the heating area of the cycle if you did that and turned it on and still humming you  have a bad motor
Jun 07, 2009 | Maytag SDE3606A Electric Dryer
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Hot Point Dryer does not come on but you can hear the noise by the start knob like a low buzz
Feel the outer cover at rear of the dryer at the bottom,if it starts to feel warm then the heater is working, the buzzing noise could be the motor trying to start, or noise from the relay, if the heater does not come on then could be timer faulty or faulty start relay. It is a a process of elmination.
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Noise from timer occurs on ocasions when dryer won't start
well lol its hard to bury an old friend lol will try to help what kind of noise are you hearing sure you dont want to get six of your friends to carrey it out lol tell me as much as ya can
Dec 30, 2007 | Dryers
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
My dryer doens't start up
Depends on if you can hear any noise when you hit the start button or turn the knob. If there is a hum or some sound then could be belt or motor problems. If there is no sound dead, then you are checking the right area, there are kill switches in different places on dryers. one is like you checked the door switch, and another may be in back when you open the cover to check. Maybe fallen out of place. These sw. are for your safety and sometimes they malfunction. Hope this help!
Aug 12, 2007 | AEG T57800 Electric Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
