Question about SanDisk Sansa Clip MP3 Player
Can Charge but not connect
I can see that my sansa is charging when I connect it to my pc but it is not connected and not recognized. Please help.
  • christian_sp May 12, 2008
    i have the same problem, and i hate it
    it was working for months
    and then one day i unistalled my limewire and after that day,
    my sansa clip works great and when i plugg it in, it charges but the computer cant seem to find it.
    Can anyone help me with this problem.?
    i have tried holding the middle button for 5-7 seconds and installing that one piece of hardware they had told me to installl, but still no luck .
    anyone have any other solutions?
I can't put my music from the computer into my mp3
Posted on May 11, 2008
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I'm trying to charge my Sansa MP3 player but am getting and error USB Device Not Recognized Help PLEASE!!!!
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier I used my friends labtop it worked USB 2.0
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
A big help here..sansa e250 go damn..,
i cannot delete saved songs form my mp3. can you help me
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
Sansa c250
Get a USB cord and connect it to the computer. It will automatically charge with no software installed on your computer.
Mar 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa E260 Charging Problem
The battery may have become disconnected from the contacts, therefore it will not charge the battery but lights up when connected to the PC. Remove the 4 screws on the back, remove and re-seat the battery. Charge the device for a few hours. Best of Luck. p.s.- you can add to this question if this didnt help.
Oct 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
