Question about Clavia Nord Stage 88 - Digital Stage Piano NS88
The after touch sensitivity on the Nord Stage EX 88 seems to be very low and I need to press down very hard to make the sound that I want with it. Please help.
    President:
  • 1,137 Answers
Here is a link to their support where you can download the latest operating system, manual etc.:http://www.clavia.se/main.asp?tm=Support Consider joining the forum. There are always helpful members who quite likely have experienced some of the same problems. You didn't mention if that happens when you play piano, organ or synth as the setting changes you make can affect each differently. Here is a link to the download page for Windows:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osw Here is the one for Mac:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osx Pages 61 and 62 of the manual are good starting places. Aftertouch can be assigned to different functions. You will need to read Morph Assign also on page 60. Page 33 explains Velocity Sensitivity which is different from Aftertouch. If the Aftertouch is not giving you enough control over a parameter, try using the Wheel or a pedal for that parameter instead. Here is a link to the manual:http://www.nordkeyboards.com/downloads/manuals/nord%20stage/Nord%20Stage%20EX%20Manual%20v6.x%20%28eng%29.pdf The Factory Reset function is on page 68.
Posted on Aug 25, 2010
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
I just got a 18 month old privia px130 and when I play the G keys (middle and -1) and the -1C there is a hissing sound. If it only happens in the electric piano setting. If I set it on duet, it happens...
First thing is to verify if the sound is there using headphones. This is important test as it isolates problems in power amps and other connected equipment that may be sensitive to the particular pitch of those keys. If it is in the headphones, then likely you will have to take it to a repair shop as the problem would be very deep in the unit's sound generator hardware.
Jul 25, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
YPG535 keyboard is touch sensitive though one key suddenly makes a hammering (hard) sound when touching softly (seems to have lost its touch sensitivity). Does anyone have any insights on this issue?
Yep! Each key has two contacts, These are often conductive rubber pills that are pressed by the keys onto circuit traces completing the circuit. One of the contacts makes before the other so the procesor can measure the time between the closure of the two contacts. When one of the contacts doesn't make, the velocity is sensed as MAXIMUM so it HAMMERS !!!
Your problem is a contact isn't making... Your probllem to fix it is to ACCESS the contacts to clean them. Clean the contacts with ONLY 99% isoprophyl alcohol and Q tips.
Mar 01, 2011 | Yamaha YPG-535 88 Portable Electronic...
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Nord keys not making sound
This will have the weighted keys.
The contacts for the dead keys are dirty and have to be cleaned. This type keyboard is NOT DIY unless you are adept at electronics. The actual contacts are accessable after a lot of dis-assembly.
They are conductive rubber that is pressed against circuit traces on circuit board.
Use ONLY 99% isoprophyl alcohol and QTips to clean both the contact and the circuit traces they press against. Clean ALL the contacts when you have the unit open as others are sure to become inoperative as well.
Jul 20, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Clavia Nord Stage EX88 dir. in active monitor damage the speakers (tweeter) ? Happened twice with active monitors: Peavey Impulse P1020 and Behringer B-300 Peter ;-)
It is VERY easy to send to high a level to speakers.
A few important things:
ALL interconnected equipment MUST be powered from a single point. This avoids ground loops that can set up feedback. Powering monitorss at one end of a room from a receptacle and the synth at the other end of the room is inviting trouble.
REMEMBER that audio sent to the speakers that is causing the damage MAY be well above one's hearing range!
Use BALANCED audio lines where possible. CHECK that in's and out's are compatible, for instance both BALANCED TRS.
Use PROPER cables for interconnecting. Using plain stereo TRS cables for interconnecting TRS balanced lines is a NO-NO... they are cheaper but invite trouble.
If in close proximity to radio transmitters, interference can be a problem due to rectification of the radio signals that can create frequencies beyond the hearing range that can damage speakers.
The starting point is a post mortem on a failed speaker to look for damage.
The Behringer definitely requires a TRS or XLR input. I searched for a user manual online for the Nord but was unable to find one to verify they have a balanced output to run to the monitors.
There is a possibility that a filter in the NORD is NOT working, allowing digitizing noise to be presented on the output audio causing overloading of the tweeter speakers. The best way to check that is with an oscilloscope if you have access to one.
I would turn down the high eq on any active speaker to reduce the signal to the tweeter as an interim step.
Apr 29, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
When I plug the sustain pedal in, it remains on sustain (regardless of whether I push the pedal or not, so it's not the polarity that's a problem)
Try testing your switch for function by testing it with a volt ohm meter to make sure the cord and switch are functional. In this case if it is the recommended foot switch it will be momentary on or off. That is if you are using your meter to test across the plug, when you press down you should have no resistance displayed if there was resistance when you connected the probes or resistance displayed if there was none when you originally connected the probes. If the switch is good, your problem is internal to the keyboard and you will have to troubleshoot the circuit on the board. Another possibility is the solder joint has failed where the sustain pedal jack is mounted or the jack itself has failed.
Jan 24, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
One of the buttons is sticking on my Nord Stage (the amp button). How can I fix it?
FROM DOCTOR FIX . SPRAY WITH WD 40. THEN CLEAN UP WITH A PAPER TOWEL, ALL SPRAY.
WD 40 IS NOT A OIL, IT IS A STRIPPER.
Jul 07, 2009 | Clavia Nord Stage 88 - Digital Stage Piano...
Clavia Nord Stage 88 - Digital Stage Piano NS88 Logo
416 people viewed this question
Top Clavia Music Experts
Vito Vacirca Jr.
Are you a Clavia Music Expert? Answer questions, earn points and help others
