Question about Northstar Pressure Washer 3000 PSI
Very Hard to Pull Cord to start engine on Northstar Pressure Washer. When I remove spark-plug it is very easy to pull cord. With plug reinserted it is extremely difficult to pull cord to start engine.
    New Friend:
On the Honda motors very hard pull starting with no start ck for broken rocker on exhaust or intake, I've already repaired two with this problem......
Posted on Jun 20, 2015
    Problem Solver:
  • 18 Answers
You need to keep the gun open so allowed water to flow and not overpressure the pump.
Posted on Aug 25, 2010
Engine starts then stalls after 3 or 3 minutes of spraying. Then when I try to restart pull cord is really hard to pull.
When starting make sure you pull the handle to spray so it relieves the pressure from the pump an engine
Dec 19, 2015 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Mitm power washer won!t start
you might have left gas in the carb an its solidified some in tank an lines.
remove spark plug
see how the engine turns now w/o spark plug ,should crank very easy.
an squirt some gas 1oz in cylinder an close an leave it a day to soak in.
then.
see if there is a screw with spring wrapped around it ,under a metal bulb on side of engine remove the screw an clean it . look for a tiny hole in the side of the screw its hard to see . its clogged.
check you oil for water an correct level not too much or its hard to crank.
Jul 13, 2014 | Karcher 2500 PSI Pressure Washer
I cant pull the cord, everything seems to be frozen
It is possible the motor is seized or the pump component has jammed. The Honda Motor usually has an oil minder(wont start if low oil). So that being the case you may have a problem with the pump. If you are handy and have internet it is possible to download a parts/repair manual for the type of pump involved. Otherwise take it to a repair shop. Sometimes these pressure washers are more costly to fix as compared to a new one..
Nov 06, 2011 | Honda Maxus Prosumer MX5223 Pressure...
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
The cord we pull to start the washer machine is stuck
So it's stuck out? If so loosen the recoil assy's bolts and it will snap back once it's loose enough. This usually happen due to bent recoil cover, swelling of the pull rope, or too much pull rope in the recoil (length).
Or it stuck in and won't pull over. If so remove the spark plug and see if it will pull. Keep away from the spark plug oil since if the unit is flooded with fuel or oil it will shoot out of the hole and cover you with it. If it does not pull over without the spark plug in, there is a 90% chance your motor is blown.
Let me know what you find
Mar 30, 2009 | Northstar Pressure Washer Trigger Spray...
Pull cord won't pull
I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.
Mar 24, 2009 | Honda Maxus Pressure Washer MX5222
Northstar Pressure Washer 3000 PSI Logo
1,246 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
