Question about Casio FX-300MS Calculator
How to use log values in calculators - Casio FX-300MS Calculator
  • Casio Master
  • 7,993 Answers
You have two keys [LN] and [LOG], the former to calculate the natural logarithms and the latter to calculate the logarithms in base 10. You press the appropriate function key then type in the value. No need to press the [=] sign.
In case you are wondering: these functions have inverses: the inverse function of [LN] is the exponential, accessed with the key sequence [SHIFT][LN]; the inverse function of the logarithm in base 10 is "raise to to a power", accessed with the key sequence [SHIFT][LOG].
I am enclosing a screen capture from the user's manual. It shows you several examples.
Posted on Aug 24, 2010
4 Suggested Answers
vladp995
  • 81 Answers
SOURCE: Using logs
Here something that would help you:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
so log 24 base 2 it's log 24 / log 2 etc.
and if i get right what you wrote x= 10 ^ ( 3 * (log 5) ) if no inverse it it's easy really Hope it's helped you.
Posted on Jul 06, 2009
SOURCE: how to calculate log value in calculator with different base value
to calculate logb to base a,perform logb /loga
Posted on May 17, 2008
vladp995
  • 81 Answers
SOURCE: how to calculate logarithm values with different base
Like you maybe know in math (I know!) log x base y = log x / log y
so what you need its just input your number (x for example) and log it, than divide log x by log 2.
just: log x / log 2. (by the way in calculator the meaning of log x is log x base 10 the default base is 10)
Finding value of log with base 10
Use the "log" key. For example, to calculate the log base 10 of 2, press
"log" "2" =
Mar 29, 2012 | Casio FX991ES Scientific Calculator
How to find pH
Do you have the concentration? if YES, you CALCULATE the pH with the relation
pH=-log(c) where c is the value of concentration in mol/L.
ex: c= 3.57x10^(-6)
pH: (-) [LOG] 3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press [(-)]
If you have the pH, and want to calculate the concentration that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
Here is a screen capture to show you both calculations
Dec 05, 2011 | Texas Instruments TI-Nspire Graphic...
How do i give the value of log
For common log, use the LOG key. For natural log, use the LN key. In either case, enter (or calculate) the value of the argument and then press the appropriate key.
To calculate the common log of 2, press 2 LOG =
To calculate the natural log of 2, press 2 LN =
Sep 08, 2011 | Texas Instruments TI-30XA Calculator
When I go to use the 'log' button on TI 30XA I do not come up with the same answer as in my course book (for the examples) No real instructions on logs in the little instruction book. Have tried...
You calculate the pH with the relation
ex: c[H+]= 3.57x10^(-6)
c= 10^(-pH)
Ex pH=8.23
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
May 17, 2011 | Texas Instruments TI-30XA Calculator
Conversion of log base 10 to log base 2
To calculate the log base 2 of a value, calculate its log and then divide by the log of 2. You can use either the log or the ln keys, but be consistent. For example, to calculate the log base 2 of 16, you can calculate either log(16)/log(2) or ln(16)/ln(2).
Nov 27, 2010 | Casio FX570MS Scientific Calculator
How do I calculate pH from H+ concentration on a ti 30a? [H+] 1.2 x 10 -5 M = ? pH = 4.9 I worked out pH to concentration but struggling for the opposite figured it out once and...
c= 10^(-pH)
Ex pH=8.23
General shortcut.
May 20, 2010 | Texas Instruments TI-30XA Calculator
Y=log x on calculator
the log of x is always 1 if your function reads y=log(x). if you insert a value for x, hit log, then enter the value, close the parentheses and hit enter for the value
May 01, 2010 | Texas Instruments TI-30 XIIS Calculator
Some y values in my table say error when i graph logs
That is normal behavior. The log functions are not defined if the argument (x value ) is negative.
Mar 23, 2010 | Texas Instruments TI-83 Plus Calculator
How to find pka value
If I guessed right you are talking about the Chemistry notion of the pKa
Let the equilibrium constant be Ka =1.8x10^(-5). Then by definition pKa=-log(Ka) , log in base 10
pKa = - log(1.8x 10^(-5))
First set [MODE] to [COMP] by pressing [MODE] 1.
[LOG] [(] 1.8 [x] [SHIFT] [10 to the x] [(-)] 5 [)] . [(-)]
The [(-)] key is the change sign key : a small - between parentheses. The last [(-)] sign in the expression takes the negative of the whole calculation to obtain the correct value of the pKa.
The value you should find for the above exemple is 4.74
Hope it helps.
Dec 17, 2008 | Casio FX-115MS Plus Calculator
How to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be  calculated with either ln or log function as follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Dec 08, 2007 | Casio FX-300MS Calculator
Casio FX-300MS Calculator Logo
284 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
