Question about Intex 18 ft x 48" Easy Set Inflatable Swimming Pool+Pump ()
The water level in my pool dropped over a foot overnight. I refilled and within hours it dropped again. How do I find the cause/leak and repair it? Thanks
Check for any signs of water by hoses/pump....outside of pool on ground and leaks by under the inflatable ring outside...good luck!we had a neighbor or stray cat that would jump onto ring to drink!caught it after seeing "foot prints"....had to wait and catch it...but scared her with hose and patched pool...had teeny points from claws!
Posted on May 30, 2011
Tip
Bucket Testing to Locate Leaks In Your Swimming Pool
<span>How To Conduct a Swimming Pool Leak Detection Using A Simple Bucket Test </span> <p><img src="Bucket.jpg" />In Arizona, you can see up a 3/4" per day loss through evaporation and it is suspected that during the course of a year, that nearly 3/4 of the pool would have been replaced due to evaporation. <br /> <p><span>Evaporation will vary greatly </span><span>depending</span><span> on a several factors; water temperature, air temperature, wind, dew points, barometric pressures and just overall changes in seasons. Also, if you heat your pool, you will also notice variations in evaporation. Because of these factors, evaporation rates can fluctuate from day to day, pool to pool, and of course, from parts of the country to others.</span><br /> <p>It is amazing how many people call in with concerns of leaks in their pool. They really are not sure <i>why</i> they are concerned but something has caught their attention and caused concern.<br /> <p>Before becoming too concerned about a leak, or spending the money on an expensive leak detection, conduct simple bucket test to determine if water loss in your swimming pool is due to a leak or is just evaporation. <br /> <p>In a nut shell, a bucket test exposes water in a bucket to the same conditions as those affecting your swimming pool. By comparing the water loss in the bucket to that in the pool, it is possible to determine if the pool is leaking or if supposed leaks are just the result of water being lost to the air.<br /> <p>Before undertaking any test, make sure your automatic water leveler is turned off!<br /> Bucket Test Procedure: <ol> <li>Bring the pool water to its normal level</li> <li>Fill an empty bucket with pool water to about one inch from the top of bucket. (By filling the bucket close to the top you are ensuring that air movement over the surface of the bucket will similar to that of the pool.)</li> <li>Place the bucket on the first or second step of the pool. To keep it from floating away it may be necessary to place a few bricks or rocks into the bucket. (By placing the bucket in the pool water you are ensuring that the water temperature of each body of water will be similar).</li> <li>Mark the water level inside the bucket with a permanent marker on the outside of the bucket.</li> <li>Mark the water level of the pool on the outside of the bucket, on the pool wall, or skimmer face plate. I recommend the bucket, because then you have something tangible to look at. </li> <li>Operate the pool for 24 hours as it had been operated when a leak was first suspected, in most cases, this will be the normal run times. </li> <li>After 24 hours, make a second mark on the bucket to indicate the level of the water in the bucket and do the same for the pool level.</li> <li>Compare the two levels. If the pool water has changed more than the inside water level, there is probably a leak. At this point, you should contact a professional leak detection agency.</li></ol> <span>You are probably wondering how this works when the body of waters are so vastly different in size. It all comes down to <i>surface area</i>. No matter how large or how small, environmental factors act the same on the surface area of the body you are testing. </span> <span><br /></span> Further Diagnosis: Establishing suspected leak locations with a "Pump on/Pump off test" <br /> <p>Comparing the results of the bucket tests with the pump on for 24 hours to the results with the pump off for 24 hours can provide additional information as to the type of leaking you may be experiencing. <br /> <p>Conduct a second bucket test with the equipment sitting idle. Do the same steps as noted above. Any leaks during this time are now called <b>static leaks.</b><br /> <p>Water loss pump on &gt; water loss pump off = suspect return plumbing leaks (Pressure side plumbing)<br /> <p><b><u>RESULT #1:</u></b> Water Loss Active <b>greater than </b> Water Loss Static <br /> <p><u>PROBABILITY:</u> Skimmer/main drain or other plumbing leaks (return lines, infloor system, aerator)\<br /> <p><b><u>RESULT #2:</u></b> Water Loss Active <b>equal to </b>Water Loss Static <br /> <p><u>PROBABILITY:</u> suspect shell, liner or fitting leaks, (non-plumbing)<br /> <p>If you have an in floor cleaning system, water feature or specialty items on your pool you should also conduct independent tests with each of these in the normal operation and compare them against other results when they are not in operation.<br /> <p>These types of tests are not 100%, but they do provide you with enough information to determine if further leak detection is necessary and to provide the leak detection company with some great information!<br /> <p><br /> <p>We hope to have been of service to you!<br /> <p>The Ugly Pool Guy, <a href="http://www.wefixuglypools.com">www.WeFixUglyPools.com</a><br />
on Dec 15, 2010 | Pool & Spa
Tip
////////////Detecting The Hole In A Leaking Pool Liner////////////
Pool liner has a hole in it....you keep adding water far too many times a week running up your water bills far to high....you call a pool guy and he recommends a "Diver" to call, when you call the diver you fall through the floor when he tells you the initial cost no matter whether he finds the leak or not.
This is what i have learned from the experts....had a pool diver come over and all he did was 'Nothing"...he charged me $400.00 took out and resealed my lights...broke my brick stones around the pool in various places due to his removal of the air tanks, talked a good line of balogna, took my check and left....left me $400.00 lighter in my wallet and no better off then I was before concerning my pool liner leak, he even told me after he came back to find it three times again that the leak was all in my mind and that the dropping of the water level was due to evaporation... this is all good fior someone who is new to a pool...but I have had this inground pool for 10 years prior to him telling me he usually always finds the leaks....he did not and tried to cover his inadequecies with a ration of bull stories...I was adding at least 2-3 hundred gallons of water everyday whether it was hot out or cold out, and this only started happening after about 10 years of owning the pool, in this case it didnot pay to have someone dive the pool because when you can see a real strong discoloration in your liner and the water level starts to drop all of a sudden every other day to at least 1/2-1.0 inches it is time to replace the liner.
If you have a newer then 8-10 year old liner by all means have it tested before you replace it, a cheap and inexpensive way to do this is to start at some point... I would first buy a $4.00 rubber plug to plug up the bottom drain....see if the water level drops...if it does problem is someplace else if it stops dropping the prblem is in the drain lines and that can be an expensive fix for an inground pool short of just leaving it plugged and never using the bottom drain feature again.
If the drain plugging doesn't fix the problem try blocking off the lines with plugs one at a time until you find the level stops dropping indicating which line is culprit, including the skimmers and please be sure you leave the filter off while doing these tests.
If none of the above finds the leaks get in the pool and being very still discharge a small puff of red food coloring under water around the light lense frames...trying to see if it gets sucked into a leaking area, also around the stair case if so equipped doing the same thing with the dye around the seams etc.
You may even find the filter is leaking at a joint causing the leak, or like i once found.... little under ground critters ate my skimmer lines... they punched pin holes into the rubber buried lines with there teeth...they were small moles, nocturnal like rodents that burrow under ground causing havoc on anything that is buried beneath the surface....I found this problem easily...the ground all of a sudden became wet and damp and eventually started to pool up with water for no apparnt reason...when I dug into the water pool I found a little gusher of water coming from the lines, these critters ate into the lines...had to cut them and couple them with a sleeve for the fix.
on Sep 17, 2010 | Plumbing
Above ground pool leak
Is this an above ground pool or an in ground pool? As a general rule you don't want vinyl to go too long without water. Water helps things stay in place. If the vinyl starts to shrink and bow inward there is a good chance that it will lose its elasticity and split when the pool is being refilled. I would advise you to go ahead and refill the pool. Leaks can be repaired underwater. In the event of a split I'd go back to the installer and pursue a new liner at his expense.
Jan 28, 2013 | Pool & Spa
Our water level in our pool dropped over a foot overnight
Depending on the size of your pool that's allot of water, check your switching valve it might have a bad gasket OR if your pool has trees near it roots can break the plumbing
You will need to keep a eye on your pump now it may have ran dry and damaged the shaft seal, look for a wet spot under the pump if you see one the shaft seal MUST BE CHANGED ASAP. failure to do so will cause water to leak into the motor and damage the bearing and as a bonus the bad bearing will cause the motor to consume large amounts of electricity, easy fix. I only charge $20 to install a shaft seal,seal included "most pumps" (if u bring in pump) use only quality seal there are seals available on Ebay like these... please PRIME THE PUMP AFTER ANY PUMP REPAIR !
Jay the pool pump motor repair guy longwood fl 32750
Dec 28, 2012 | Pool & Spa
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a...
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Im filliing my intex pool and found water trickleing from underneath, how can i find the leak. or should i continue to fill to better locate the leak?
Now let's find that leak! Fill the pool to its normal level and mark it. A piece of duct tape is ideal for this. Next with your filter system running the whole time, wait 12 to 24 hours and measure the loss of water. Then refill the pool back to the same level and with the filter system off, wait the same amount of time (also over the same part of the day, ie. 8 AM to 8 AM or 7 PM to 7 AM) and measure the water loss.
If you are losing more water with the filter system running, the leak is on the pressure side of your plumbing somewhere PAST the impeller of the pump. If you are losing less water with the filter system not running, the leak is on the vacuum side of your plumbing somewhere BEFORE the impeller of the pump. Please note that in this case, most of the time the pool only loses water when the system is off and not when it's on. If the water loss is the same, then your leak is in the structure of the pool and not in the plumbing.
Let's deal with a leak in the plumbing first. We will assume that there is not an obvious leak (one that you can see) on the filter system. Did you check where your backwash line comes out? There are two ways to find this leak. First, you can pressure test the lines, then dig, following the leaking line till you find it. You can also call in your local leak detection service. We would highly recommend the latter, unless you like to dig. Professionals will use "geophones" to listen for the leak and only dig where necessary!
Now lets look at a leak in the structure of a concrete pool. You will need some food coloring for this, and you will want to turn off the pump at least an hour before you do this. In a concrete pool, any cracks in the shell are usually obvious. By squeezing out the food coloring near the crack, you will see the crack pull the food coloring in. That will show you where the pool is leaking. Yes, you may have to get in the pool to do this, but isn't that why you got the pool in the first place? If there are no visible cracks, you will want to squeeze out the food coloring around any of the items that pierce the shell of the pool (main drain, returns, lights, etc.). Be sure to check the "mouth" of the skimmer where the plastic of the skimmer meets the concrete. This area is very susceptible to movement and often separates causing a leak.
Once the leak is found, it is easy to fix using a patching material. Most of them will work under water. After patching, check again with your food coloring to make sure you plugged the leak. Please note that if you patch near a fitting, you will want to leave the pump off while it cures, so the flow of water doesn't wash the patch away.
What if you have a vinyl pool with a leak? A leak can be a little harder to find and fix in a vinyl pool, but it's not impossible. We would recommend that you first check around all the items that pierce the liner (main drain, returns, lights, etc.). If you find that the liner has pulled away or is leaking behind a fitting, we would STRONGLY recommend that you call in your local pool professional at this point. If you mess this repair up you could easily be looking at a new liner!
If you do not detect a leak around the fittings, you will need to search the liner itself. A lot of vinyl liners have a pattern on the walls or bottom which can make it difficult to see a hole. Sometimes by running your hand over the floor and walls you may feel a tear or puncture that's not easily visible. If you have a friend who is a diver, he or she can do the job a lot easier with a tank than you can by holding your breath. Note: only certified divers should be using diving gear, even in a pool. Sometimes there is a depression on the floor which might indicate erosion caused by the flow of water. After finding the leak it is an easy matter to patch, using a vinyl patch kit and following the directions.
i hope this helps...let me know, thanks and good luck
Jun 27, 2010 | Intex Easy Set Pool 15x36
Water level drops during wash/rinse cycle
Check the exit hose behind, it should be at least 3 feet from ground level, and not too deep into the wall stand-pipe. You will find a level mark behind the machine......check this out.
Your pump pumps this water OVER this height.
Dec 03, 2007 | Washing Machines
Intex 18 ft x 48" Easy Set Inflatable Swimming Pool+Pump () Logo
539 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
