Question about Intex 18 ft x 48" Easy Set Inflatable Swimming Pool+Pump ()
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a foot. At first I attributed it to a change in temperature (the weather suddenly was much cooler). I refilled the pool to the correct level and within hours the water level was back down. How do I find the leak and how do I repair it? Thanks
  • Intex Master
  • 8,404 Answers
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Posted on Aug 27, 2010
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
try to get the vacuum that works with the garden hose they work ok for the small pools
The blow up rim on my pool is on the inside, what happened?!
deal with it until you drain it you might do damage it might not be structurally sound this way
Jul 03, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
Water pressure in to the pool has vanished. No
CHECK FOR A BLOCKAGE IN BETWEEN THE OUTLET AND THE PUMP MAY HAVE HAIR OR TRASH SIDE OF THE PUMP AS THERE IS A BUILT IN STRAINER THERE. ALSO CHECK YOUR PLUNGER VALVE AND SEE IF ITS CLEAR.
Jul 30, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Air leak in ring
JOJO I FIND THAT THE SOAP YOU USE TO BLOW BUBBLES WITH WORKS THE BEST, BLOW THE RING UP REAL GOOD, AND GO SLOW. I HAVE USED CELLOPHANE TAPE TO FIX LEAKS ON MY WATERBED
May 20, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Intex 18 ft x 48" Easy Set Inflatable Swimming Pool+Pump () Logo
160 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
