Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
The washer keeps beeping and trying to drain as soon as it is turned on
  • 1 more comment
  • Meldrum Jun 24, 2008
    Haia dishwasher just keeps flashing its lights every ten seconds or so and beeping While this is happening it is constantly running the draining pump. there is no water in machine. Have tried`unplugging and leaving for a while.
  • agustinem Dec 01, 2008
    Hi
    Ive got the same problem, any answers?
    My model is bfd60ss
  • darianas May 11, 2010
    It works, I tilted it forward, it spilled, then it worked.
  • 3 Answers
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
Posted on Dec 19, 2008
Exact same problem. Turned the unit on and the drain pump just kept running even though no water was in the dishwasher. I kept filling it up manually with a bucket and closing it up and it would drain and just keep attempting to drain after the water was all gone. I was hoping by filling it up whatever tells the unit to stop draining would do its job. No sch luck. Eventually it would beep but would not turn off it just kept trying to drain. I suppose it would have burned the motor out it I left it that way. After reading this thread I turned the unit on and tilted it forward 45 degrees and the pump stopped. I turned it on and off and it worked normally again. Thank you.
Posted on May 31, 2009
I had the same problem and was searching online and came accross this post and by tilting the dishwasher forward it seemed to do the trick!!! Thanks
Posted on Oct 19, 2009
    Genius:
  • 1,073 Answers
What is the model nunber of the dishwasher
Posted on May 05, 2008
This worked for me too! Thanks
Posted on Sep 22, 2011
My Sears Limited Edition washer starts the drain pump as soon as you turn it on and the pump keeps running continuously(I can hear it) which doesn't allow the water to fill the tub?As soon as it start
check the drain hose,if it's pushed down the stand pipe to far it will cause a syphoning affect and drain the water out as fast as it goes in,also have you unplugged the washer to reset the computer board?if not unplug it for 5 to 10 minutes,plug it back in and see if it resets itself,any error codes coming up?let me know how you make out.
Dec 14, 2014 | Washing Machines
Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Kenmore he3t front load washer doesn't turn on, only two beeps. I've tried unplugging it and same result.
Mar 24, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
SUB/F....NOT DRAINING AND BEEPING
hello mam
drain pump of the washer is not working or the filtr will be blocked filter will be located at the outer bottom of the washer.please check it.
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer cycle signal keeps going off an on turing cy
Jan 04, 2009 | Kenmore Washing Machines
Fisher&Paukel washer
might have something stuck in drainage area. see my post on "eco smart won't drain, smells hot" on how to remove motor on bottom of washer.
might also try another website, www.ths.gardenweb.com/forum/laundry to see if anyone on there has an answer.
Oct 13, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Nov 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
2,089 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
