Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
I am installing new Belkin router F5D7234-4 v5 (01). I have done the setup according to the guide that came with the router kit. I am unable to connect to internet. The modem light keeps on blinking red color. Could it be because of the user/pwd provided by the ISP provider?
bee2busy
  • 51 Answers
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Posted on Feb 23, 2008
  • 32 Answers
SOURCE: Blinking amber light on modem icon
that means there is usually a problem with your modem. you know how to hook up a router, right? usually you unplug power from both devices, plug in your modem and let it load, then plug in your router. (with some isp's id will work the other way around.
Posted on May 10, 2009
  • 3 Answers
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
Posted on Sep 23, 2009
SOURCE: trying to install belkin enhanced wireless router
Turn everything off. I mean everything. That is, turn off the computer, the router, and the modem, unplug them, and disconnect them from each other. If the modem has a battery, remove it if you can so it shuts completely off. Wait a few minutes, then BEFORE YOU POWER ON, reconnect the signal cables... modem to router, router to PC. Then replace the battery/turn on your modem, plug your power back into your router, then turn on your PC. Hope this helps.
Posted on Nov 29, 2009
arvinds88
  • 108 Answers
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Posted on Jan 15, 2010
How do i install my belkin range extender?
restart the belkin range extender . and reset the settings i hope this works
Feb 03, 2015 | Belkin Components Belkin - Dual-band...
How do I reinstall a Belkin router
Contact Belkin for Care at 1-800-585-2494 Toll Free!!
Apr 29, 2010 | Belkin (F5D7231-4) Wireless Router
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Installation problem
Initially, I would suggest that you connect either your Dell desktop and IBM ThinkPad laptop using a wired LAN cable to any of the Ethernet Port 1~4 of the router and verify that your PC is set to Auto obtain an IP address. Thereafter pls go through the setup procedures again.
If this is how you have connected your router and PCs, pls post back that we can figurre something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N Wireless router
return it it sucks!!!!! You have to continually call belkin to reset
Jan 04, 2008 | Computers & Internet
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
102 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
