Question about DeLonghi EC701 Espresso Machine
Esam 3200-s stuck infuser - how do you remove it, ed warning light on and both cup lights constant on
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
kd6rhd56
  • 400 Answers
SOURCE: petrol gauge stuck on empty and light constantly
Sounds like a broken gas tank sensor in the gas tank. The sending unit has probably gone out.
Posted on Jul 10, 2009
Dane1234
  • 25 Answers
SOURCE: Can't remove infuser to clean it
Try unplugging the machine; wait 20 seconds; plug back in and wait for the diagnostic cycle to complete. Turn off machine. Now see if the infuser can be removed. Assuming this does the trick, before reinserting the thoroughly cleaned infuser, check that the two screws that hold the infuser holder to the back plane, which become visible when the infuser is removed, are tight. These are screws with a hex head socket, so you will need a hex screwdriver to tighten them.
Posted on Jun 29, 2010
mnwarfield10
  • 452 Answers
SOURCE: Help! The warning light regarding
motor no good may be pcb needs testing...
Posted on Mar 04, 2011
ginko
  • 19396 Answers
SOURCE: alternating 3 lights (1 cup,
Hi.
The machine is not flashing an error message. When a problem is detected you get an error message on display.
First hold down ESC (or STOP/CLEAR depending on model), just in case machine is stuck in programming mode.
Disconnect power cord for two minutes. Connect back and try a reset if the problem is not fixed:
•Press the CHANGE button and the appliance displays "RESET TO DEFAULT YES";
•Press the OK button to reset the factory default values;
•Press the MENU button to exit programming mode or NEXT to change other parameters.
If that does not work, try holding down rinse or descale. If the machine starts rinse or descale, complete the procedure. If machine gets stuck in rinse or descale, keep filling the container while performing the procedure.
If all that does not fix the problem, call Delonghi at the number listed on the owners manual, the machine is defective.
Try all the rest first, or Delonghi may ask you to do some of the same procedures while operator is waiting at the phone.
Regards.
Ginko.
Posted on Apr 06, 2011
Delonghi problems
I had a similar problem which was solved by replacing the infusor. I was able to find a new one on eBay for about $40. Hope this helps.
Jul 28, 2014 | De'Longhi Magnifica Esam4200 15-Bar Bean...
Infuser jammed in ESAM 5600 cannot get it out
Obvious question really, but is the power turned off? You cannot get the infuser out if the power is on. Or has it been reinserted recently, and incorrectly? The only time I have known of issues getting them out is if the power is on, or if the power went out when it was not parked, in which case turn the power back on it, let it go through the warm up cycle, then turn it off again, let it shut down, then remove the infuser
Jun 15, 2014 | DeLonghi Intensa ECAM 23.210 W 2-Cup...
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
How do you remove a stuck diffuser on ESAM4200. Have tried switiching it on and off but its still stuck
Hi Sue Are you sure that it is not the infuser that is stuck. Theere are a number of things you can do to try to loosen it. Has it clicked? I put the link to the manual here, you should be able to find help there, I have when I could not get my ifuser to click iuser.http://www.delonghi.com/corporate_en/products/esam-4200s-ex1/ Kolbrun
Sep 10, 2013 | DeLonghi Coffee Makers & Espresso Machines
Hello i have an Delonghi esam 4200 and the infuser got stuck can you please recommend how can i solve it
Aug 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EC701 Espresso Machine Logo
200 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
