Question about Excel Computers & Internet
Manual Page break in Excel Work Sheet more than 1026 pages
Dear Sir,
I am using Office 2003. Excel can not except manual page break more than 1026 pages.
How I resolve this problem.
Thanks
With best regards
Gopal Krishan
SOURCE: fix my problem
please you cant tell my how cant doit for instaled motorola phone tools in my computer for conect internet explred used my phone how modem and thank for try
Posted on Nov 12, 2007
  • 8 Answers
SOURCE: Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Posted on Jul 05, 2008
  • 3 Answers
SOURCE: Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Posted on Oct 15, 2008
SOURCE: Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Posted on Nov 13, 2008
PeteG0429
  • 34 Answers
SOURCE: Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Posted on Apr 02, 2009
How to delete Page breaks in Excel
Move a page break Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
  1. Under Help, click Options.
  2. In the Advanced category, under Editing options, select the Enable fill handle and cell drag-and-drop check box, and then click OK.
  3. Select the worksheet that you want to modify.
  4. On the View tab, in the Workbook Views group, click Page Break Preview.
    2. Tip You can also click Page Break Preview za010181030.gif on the status bar.
    3. Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
  5. To move a page break, drag the page break to a new location.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
  1. Select the worksheet that you want to modify.
  2. On the View tab, in the Workbook Views group, click Page Break Preview.
  1. Do one of the following:
    • To delete a vertical page break, select the column to the right of the page break that you want to delete.
    • To delete a horizontal page break, select the row below the page break that you want to delete.
Note You cannot delete an automatic page break.
Jul 20, 2014 | Microsoft Excel 2010
How to deleat a page in office word
  • To delete a page manually, select the page break at the end of the page, and then press DELETE.
  • To delete a blank page at the end of the document, select the page break or any paragraph markers at the end of the document, and then press DELETE.
Jul 01, 2014 | Microsoft Office Excel 2007 Full Version...
Remove page breaks in excel
We would appreciate if you share with us your Excel version as well so that we can give you a more specific solution to your issue. In the meanwhile, you can refer to the following steps to delete a manually-inserted page break in Excel 2007, Excel 2010, or Excel 2013:
(Important: You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.)
2. Go to "View" tab, then go to "Workbook Views" section, and click "Page Break Preview".
(Note: You can also click "Page Break Preview " on the status bar)
(Important: If you get the "Welcome to Page Break Preview" dialog box, click "OK". To avoid seeing this dialog box every time you go to "Page Break Preview" view, select "Do not show this dialog again" check box and click "OK".)
3. Now do one of the following:
a) To delete a vertical page break, select the column to the right of the page break that you want to delete.
b) To delete a horizontal page break, select the row below the page break that you want to delete.
(Note: You cannot remove automatic page breaks)
4. Go to "Page Layout", then go to "Page Setup" section, and click "Breaks"
5. Click "Remove Page Breaks"
(Important: You can also remove a page break by dragging it outside of the page break preview area {to the left or right for vertical page breaks, or up or down for horizontal page breaks}. If you cannot drag page breaks, make sure that the drag-and-drop feature is enabled. To check the status of your drag-and-drop feature, click office button , click "Excel Options" tab, click "Advanced", go to "Editing Options" and make sure you have checked the "Enable fill handle and cell drag-and-drop" option.)
To refer to a pictorial explanation of the above steps, you can refer to "Delete a manually inserted page-break" section on the following Microsoft Support Page:
http://office.microsoft.com/en-in/excel-help/remove-a-page-break-HA102576899.aspx?CTT=1
GuruAid.com
Jun 22, 2014 | Computers & Internet
Macro help in Excel
go google and type in--- user manual for excel---
there is a pdf version about 900 pages long that explains everything you want to know and do in excel
Mar 27, 2017 | Microsoft Office Excel 2003 for PC
How to rotate a page?
In Office you can change the page orientation by using the Page Setup menu commants.
In Word and Excel 2007 this is under "Page Layout", then "orientation".
In 2003 this is under "File" then "Page setup" then a dialogue box allows you to change the orientation.
Sep 11, 2011 | Microsoft Office Professional 2007 Full...
How to convert 2007 excel sheet into 2003 excel sheet
if you have excel 2007 you can save the file into excel 2003 compatibility
if you have excel 2003 need download compatibility pack from this page
http://www.microsoft.com/downloads/en/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
install it and success!
Feb 22, 2011 | Computers & Internet
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
How to edit microsoft office viewer excel page without installing any ms office software in the system.
You need XL viewer OR any software which can edit excel files. Search on google for the same.
Jun 04, 2009 | Microsoft Office Excel 2003 for PC
Microsoft excel is only opening blank (without any sheet or flie
Go to the tools menu click on options and the view tab under window options make sure everything is checked except page breaks and formulas.
Jan 16, 2009 | Microsoft Excel for PC
Computers & Internet Logo
329 people viewed this question
Top Excel Computers & Internet Experts
gary433
john h
Are you an Excel Computer and Internet Expert? Answer questions, earn points and help others
