How many ports are in bridges
Help me now
  • 13,433 Answers
Debends 1-4 mostly
Posted on May 05, 2008
Can't play other players online with PS3 because of NAT3 network configuration.
There are many reason as to why NAT3 is not open. First is the ISP's modem, verify from your ISP is set into full bridged mode. If it is just half-bridge, informed your ISP to help you set modem into full bridge mode. Second is forward the port numbers TCP: 80, 443, 5223 and UDP: 3478, 3479 in your router. You will access the set-up page of your D-link router and click "advanced tab" and choose "port forwarding"
Nov 09, 2010 | Belkin Basic Wireless Router
I need help openning ports so my online game will load faster
You can find a listing of port numbers here: http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
Jul 04, 2009 | Siemens SpeedStream 4200 (13A4200001)...
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Utorrent port forwarding
    when ya say done everything what ya mean bud????
    Aug 19, 2008 | Siemens SpeedStream 4200 (13A4200001)...
    How to reset Cisco Aironet 340 Wireless bridge?
    Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
    1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
      For more information, refer to the Cabling Guide for Console and AUX Ports.
      Note: These instructions describe HyperTeminal. Other programs are similar.
    3. Enter a name in the Connection Description window.
    4. Select an icon for the connection.
    5. Click OK.
    6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
    7. Click OK.
    8. In the Port Settings window, make these selections:
      • Bits per second (baud): 9600
      • Data bits: 8
      • Parity: None
      • Stop bits: 1
      • Flow Control: None
    9. Click OK.
    10. In the Connection Description window, enter a name and select an icon for the connection.
    11. Click OK.
    12. Press Enter.
    13. When the Main Menu screen appears, reboot the bridge.
      Turn the unit off and then back on.
    14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
    15. Press Enter.
    16. Enter Yes.
    17. Press Enter in order to confirm the command.
    18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
    see this link 340 Wireless Bridge
    Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
    Port Forwarding with BR-6104K
    hope this helps
    In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
    If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
    Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
    I have not run into CABLE providers cable modems having to do this
    did you allow that port in your computers firewall?
    Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
    User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
    instruction site
    http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
    to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
    Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
    Need help with siemes speedsteam 4200 port issues
    Please goto the below link and select your game and see the document for portmapping.
    http://portforward.com/english/routers/port_forwarding/Siemens/4200/4200index.htm
    With Regards,
    TPV
    Jan 05, 2008 | Siemens SpeedStream 4200 (13A4200001)...
    Bridge RCA Thomson DCM315R
    Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
    - Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
    - If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
    Note:
    DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
    Hope this will help you
    Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
    Computers & Internet Logo
    136 people viewed this question
    David Payne
    David Payne
