Question about Victory MULTIMEDIA THE LAPBOARDBY LAPFORM PRODUCT (LB200) Keyboard
I have toshiba LB200 mini laptop, i used it about a year,it got a problem, when i turn it on, the screen just blank, but the fan is running and the power button is lighting, what are the problems?
Toshiba satellite pskoqu screen blanking
Please check the air vents (inlet and outlet) and clean them up using a canned air, and use an external monitor to test this laptop. If the problem is not solved, then your laptop's GPU/motherboard is dying.
Mar 09, 2014 | Computers & Internet
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
Nb 205 blank screen
Is your screen blank when you are trying to turn it on? Do the fans run and such but nothing shows up? If not then I don't know.. but if it is put you laptop in the freezer for an hour. Mine had that problem, but you won't be able to turn it off... ever again... because then it won't start up again. I would suggest to check this out as well if it is that problem. http://www.techsupportforum.com/forums/f108/toshiba-nb200-wont-boot-492391.html
Apr 02, 2011 | Toshiba NB205-N311/W Netbook
Had laptop sitting in lap and turned body briefly lap top went off and will not power up. the fan runs but will not power up. screen is blank
you may have hit the sleep or standby button. Try turning the pc off by holding down the power button untill you hear the fans stop. then power up as usual.
Nov 08, 2009 | Toshiba Satellite M35X-S111 Notebook
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Hp mini screen is blank
Hello imlapd. If you don't even see words on the screen when you first turn it on (the BIOS puts things on the screen before it boots to Windows), then there are 2 possible causes. First, the video output or something else on the motherboard is bad. Second, the LCD display (the laptop screen) has failed. The cost to fix either one of these will be close to what the laptop cost brand new if not more. The good news is, if your HP Mini is less than a year old or you got an extended warranty, HP will fix it for free. You just have to call their customer service.
800-HP invent
or
800-474-6836
Be prepared to provide the following information: Serial Number (S/N), product name, model number, and a brief description of the issue.
Aug 26, 2009 | HP Mini 1000 Netbook
Computers & Internet Logo
Top Victory Computers & Internet Experts
David Payne
David Payne
Are you a Victory Computer and Internet Expert? Answer questions, earn points and help others
