Question about Nordic Track /proform Treadmill Drive/motor Belt 118016
I have a Nordic Track Bike SL720 and the petals are slipping (feels like chain is slipping) Can this be repaired and how is best way to do this
SOURCE: Nordic Track Treadmill Viewpoint 2800 : The belt
It needs to be adjusted as shown in your owners manual.
There are two allen screws located at the back end of the treadmill. That's where you adjust it. 3 - 4 inches of slack midpoint is just right
Posted on Nov 23, 2009
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
  • 11 Answers
SOURCE: My Nordic Track C2000 walking belt keeps slipping
Could be out of adjustment. Belts will stretch with time and there should be a mechanism for keeping the tension, but if you've exceeded the limit, it might slip.
Posted on Feb 24, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Posted on Oct 29, 2010
How to stop the bike from slipping
Hey
This may help you
https://www.youtube.com/watch?v=GWYERtOBFI0
Sep 25, 2016 | Nordic Track NordicTrack Commercial VR...
No tension on pedals for nordic track trl 625 recumbent bike
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
God bless you
Apr 01, 2013 | Exercise & Fitness
When you have adjusted the most you can, should you replace the belt?
If you have tightened the belt and it continues to slip it is usually a sign that the deck and belt are worn. You may be looking at repairs that might be more costly than getting a new machine. You can check the deck by sliding your hand under the belt (not running) and feeling the deck surface. If you feel grooves or any rough spots then you need to replace it. The underside of the walking belt will also feel fuzzy like a peach if the fibers are breaking down.
If the machine is not very old or hasnt had much use then it could be several other things causing the slipping/stopping of the belt.
Feb 24, 2011 | Nordic Track NordicTrack A2750 PRO...
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
Putting the cahin back on???duh???
If the chain has just slipped of the best way get it back on is to physically lift it into place at the top of the chain ring (the cog where the pedals are).
Then turn the pedals in the direction you would usually pedal (you may have to lift the back wheel off the ground).
This ought to pull the chain back on and let you get back on the open road.
Jul 12, 2010 | Schwinn Windwood 26 Men s Cruiser Bicycle
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Feb 05, 2010 | NordicTrack Exercise & Fitness
Jan 18, 2010 | Exercise & Fitness
Chain
Go to any reputable shop/mechanic; you probably need a new chain and/or sprocket...OR Possibly just a chain adjustment. Don't wait around, do it asap, I wouldn' t play with this particular problem.
Nov 20, 2008 | 1990 Suzuki RGV 250 L
Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
218 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
