Question about Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E
I have a etq 1200 generator 2 years old never used the other day wanted to start up but it's imposible. There is no spark at spark plug wunder how to check Hi voltage set. Thank you john
  • 44 Answers
Check to make sure no rust around magneto
Posted on Sep 09, 2010
    Problem Solver:
  • 5 Answers
Buy a new spark plug. Remove the old spark plug. Make the unit is on. Have someone hold the spark plug really close to the cylinder head or very top of the motor. Make sure the Motor. NOT THE GAS TANK! There should be a blue spark. If not, you can then bypass the whole systems electrical on/off switch and run the test on the spark plug again. To bypass you can just connect the 2 wires underneath the cover-(that hooks to the on/off switch)
Posted on Apr 23, 2013
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Nov 25, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
I have a etq 1200 generator that runs but doesnt have ac. what could be the problem?
Check that the GFI receptical is not tripped
Check that there are no blown fuses or tripped breakers
Verify that the engine is running at full RPM
If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Sep 04, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E Logo
671 people viewed this question
Top Eastern Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Eastern Electrical Supply Expert? Answer questions, earn points and help others
