Question about Texas Instruments TI-5019 Calculator
BATTERIES AND PAPER?
WHERE CAN I GET THEM?
  • DONER May 05, 2008
    INK RIBBON? DONER TI-5019
  • 1,512 Answers
Hi doner
The calc uses AA penlight batteries, you can get them anywhere, service stations, seven eleven, hardware store. It uses standard paper rolls too, you will need to go to an stationary shop, or office supplies, and they will have them, and the batteries too. :) Any problems, I am here to help.
regards
robotek
Posted on May 05, 2008
  • Graeme Ross
    Graeme Ross May 05, 2008
    Hi again... they do not use a ribbon as such, but have a roller instead. You could get one from anywhere that they sell Texas Instruments products(most office shops), or you could order on online from here. Hope this helps
    A FixYa rating would be great for this advice... feel free to ask for more information, I am your man :)
    robotek
I like to change oil seal of power steering of santro xing car of 2004 model.
Justice password journal low batteries
I used a set of cutting pliers and lifted the back two rivets off. Then i gently peeled the paper up and slid a knife under the strap that was glued down. Replaced the batteries, put the rivets back in and used a small screw driver to mesh the strap back on the rivets. Lightly re-glued the strap and scotch taped the paper back on. Back in business, made one girl happy!
Dec 26, 2013 | Justice Girls Electronic Password Journal
My Eton E5 will not reset when I put a paper klip in the reset hole.
Unplug the AC adapter. Remove the batteries. Press & hold down any front panel button for about 10 seconds. Repeat for any 2 more buttons. Then reset with the paper clip. Do not install weak batteries, or try to restart or reset the radio after it shut off because of weak batteries. Weak, dead, or shorted batteries, tend to make the processor inside or the reset function to screw up.
Oct 18, 2013 | Eton E5 Radio
Will not dispense towels. We pull the batteries out and put them back in. Sensor will pick up twice and dispense normally then it quits. replaced batteries....same thing happens. green and red lights...
Is there a reset button or a hole that requires a paper clip or nail? Sometimes reset means leaving the batteries out for 5-10 minutes. Have you contacted the manufacturer? - Especially if this a new purchase. Then I'd return it or exchange it.
Oct 17, 2013 | San Jamar T8400TBK - Compact Touchless...
How to turn off the mouse when travelling or when not in use without taking of the batteries?
Unless that mouse has a switch to turn it off...no luck, but an alternative is to take a piece of note paper or thin plastic and open your mouse to the batteries and push a little piece of the paper or thin plastic in between either of the batteries and its end metal contact and there you have it! To get it up an running just pull out the paper or plastic!
Jan 02, 2013 | NexxTech NWOMMI Mouse
I have the dymo letratag. no letters come out on the paper. I can not find anywhere to put any ink.
LetraTag label makers are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in.
Jan 29, 2011 | Dymo LetraTAG Thermal Label Printer
MY HP 11C Calaculaltor has quit working. I changed the batteries and the screen only blinked a few times. How can I get this fixed? Where can I send this calculator to be repaired?
Try this first. Take out the batteries. Now take a paper clip and bend it into a "U" shape. In the well where the batteries go touch one end of the paper clip to one battery terminal while touching the other end of the paper clip to the other battery terminal. Hold it like this for 30 seconds or so. This effectively dumps any residual charge from the calculator. Now, reinstall the batteries and try turning it on. Assuming this doesn't work I'm afraid you're in the market for a new calculator. HP no longer repairs these so your best bet will be to replace it with the HP35s. The 11c can be found on ebay but they are extremely expensive. Good luck
Aug 02, 2010 | HP 12c Calculator
Seems like my ink has dried any way to get it printing again
Thermal printers don't have ink, the head heats the special thermal paper and 'burns' the image into it.
Either the paper is not working (too old?) or the head isn't heating. Try some new paper if possible.
Apr 04, 2010 | Dymo LetraTAG Thermal Label Printer
Faint type on metallic refills
Faded print is nearly always the 1st sign the batteries are nearly worn out - try new batteries. (it could be that metalic tape requires more power to print than the paper tape)
Jan 18, 2009 | Dymo LetraTAG Thermal Label Printer
Texas Instruments TI-5019 Calculator Logo
128 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
