Question about Brother MFC-8860DN Printer
Scan to email keeps shooting back an error poor line condition/out of memory but I also noticed right before it prints me this error it says not registered on the little screen not sure if that has something t do with it or not
  • 105 Answers
SOURCE: OUT OF MEMORY
Just because you can hear fine when you call the same number and talk to the person there, does not mean a fax machine won't sense noise on the line. A fax machine is much more sensitive, and cannot have a lot of noise or it will not be able to render the image at the other end correctly. So have your phone company and the recipient's phone company check the lines for problems.
There is also the chance that the two fax machines cannot get along. We have clients that we cannot use our fax machine for, because it always generates a similar error to yours. If we go to the other side of our building and use a separate fax machine on a different line, it goes through just fine.
The other half of the error is out of memory. If you have not tried these ideas, try them also: To gain extra memory, you can turn off Fax Storage, print fax messages in memory or cancel a Delayed Fax or Polling Job. In general, shutting the unit off will purge most everything out of memory.
Posted on May 13, 2008
dahaka
  • 347 Answers
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Posted on Jul 22, 2008
Healeyman
  • 1198 Answers
SOURCE: MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Posted on Apr 29, 2009
  • 4090 Answers
SOURCE: Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Posted on Nov 24, 2009
Patzky
  • 240 Answers
SOURCE: mfc-9840cdw scan poor line condition out of memory
Poor line condition / out of memory is almost always caused by poor line condition.
This is to say that there is a problem trying to send because the signal is not going through clearly enough.
This error can be due to either your fax machine or the receiving ends fax machine.
Try sending to other numbers as a test to see if it works for other numbers (you can use 1-866-685-8587 for the brother test line)
If you get the same error no matter who you send to, you may want to try another jack or telephone cable.
If you are using a splitter, try without the splitter.
Thanks,
Pat
Posted on Apr 01, 2010
Err code 322 every time ces up on my HP 6600 print scan web copy n faxachine .
Video might not help but 322 is an error with the receiving fax machine due to poor telephone line conditions. Solution is to set the receiving machine to receive at a slower transmission speed if it still fais resend the documents in smaller sizes. Hope this helps
Apr 16, 2013 | Office Equipment & Supplies
Brother MFC 3360 C can not send fax.It show "sending" ....thats all never finished.
When my fax machine does this, it prints out an error code. Most of the times it's "Poor transmission" or "Bad line". I can duplicate the problem by trying to fax out on my VoIP line instead of my regular land line.
Anymore today, it's usually easier to scan and email the document. I can e-fax the scan if I'm sending it to someone without an email address.
Carl
Jul 10, 2011 | Brother Multi-Function Center MFC-3360c...
Mfc-9840cdw scan poor line condition out of memory - how can this be solved. i feel so dense because it appears your site has already offered solutions but i can't even find them there!
Thanks,
Pat
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Trying to send a fax error: Poor line condition/ Out of memory
Make sure by making a copy that your scanner is OK, streaks or black bands won't send properly and you need a new scan assembly, Poor line condition is just that, you need a better line or cable, If you go to fax settings and turn off error correction mode it sometimes helps as well.
Feb 01, 2010 | Brother MFC-8460N All-In-One Printer
Out of memory
trying to scan to email and it is saying 'poor line condition/out of memory. How do i correct this?
Oct 28, 2009 | Brother MFC-9840CDW Laser Printer
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
How to scan to email (pdf) for a brother MFC-9840CDW
Solution #1 has nothing to do with the issue, the thread started asked how to scan a document to email via the mfc-9840cdw, not how to scan a email with antivirus.
Try opening up ports UDP:54925 on your Windows Firewall and try scanning from your computer instead of scanning directly from the printer to a email address. I tried scanning directly from the printer to send to a email and I get a error report of "poor line condition/out of memory" even though the line is fine.
Sep 03, 2008 | Computers & Internet
Copies Poorly (black)
sounds like a resolution issue in the scanner settings.
http://tinyurl.com/6qcpgy
May 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Brother MFC-8860DN Printer Logo
371 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
