Question about Peg Perego John Deere Gator HPX Ride on Toy
Not working even with a fully charged battery. I think it's a wiring problem.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 13, 2012
Troubleshooting arctic cat atv 650 twin, fuses are good but i can not even jump start, battery is fully charged, accessory switch, lights have no power. it ran perfect 2 days ago , I have read the manual,...
I think you have a dirty connection somewhere between the battery and the starter solenoid. Or... between the battery and the frame ground. Or - possibly - one of your battery cables is destroyed.
Don't keep trying to charge it or jump-start it if the battery is fully charged - you're wasting time doing that. Track down the battery cables and find the problem. Use a test light or a meter to follow the wiring - when you find where the voltage stops, you've found the problem.
Jul 26, 2014 | ATVs
Battery light w/ fully charged battery after installing new starter
I spy with my little eye, a problem that does not include even the simplest info, like make, model, and year.
Feb 04, 2013 | Ac Delco Vehicle Parts & Accessories
Bmw 325i wagon slow starting then totally no turning over at all.All lights work dash is all lit up .Battery is fully charged car has faint click.but still wont turn over.I think it might be the starter...
I would try replacing the battery first. Even a fully charged battery can have bad cells which will cause the battery to not have enough "power" to turn over the starter/engine.
Apr 27, 2011 | 2003 BMW 325
The car is not holdong a charge. I replaced the Battery about a year ago. Today I replaced the alternator. I used jumper cables it ran for about 20 minutes and then died again. All the wires look good. Any...
FIRST, YOU MAKE SURE THE BATTERY IS FULLY CHARGED.. A GOOD BATTERY WILL GO FOR 12 HOURS EVEN IF THE ALTERNATOR IS NOT WORKING.. SECOND YOU TURN THE CAR ON.. ONCE THE CAR IS ON. YOU DISCONECT THE BATTERY,, IF THE ALTERNATOR IS GOOD , THE CAR SHOULD REMAIN ON WITHOUT A BATTERY.. IF IT SHUTS DOWN , YOU HAVE A BAD ALTERNATOR OR THE WIRING IS WRONG ONE OF THE TWO.. SHORTS ON YOUR WIRING CAN CAUSE THE BATTERY TO LOOSE POWER.. BUT NOT THAT FAST. BECAUSE IF THE SHORT WAS TO SERIOUS.. YOUR WIRING WOULD BE BURNED.. COMPLETELY..
IF THE ALTERNATOR IS OKAY,, REPLACE YOUR BATTERY,, MOST OF THE TIME BATTERIES GO BAD EASY WITH ANY LITTLE PROBLEM THE CELLS BURNOUT AND THEY DONT HOLD A CHARGE EVEN IF FULLY CHARGED THEY WILL LOOSE POWER IMMEDIATELY .. I THINK THAT IS YOUR PROBLEM.. SINCE IT ONLY LASTED LIKE 20 MINUTES.
Dec 14, 2010 | 1996 Isuzu Rodeo
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Ignition light won't go out dodge dakota 1998
I think you have a defective door ajar switch, this makes the control module think the door is open, that explains the light and the key in ignition warning.
Mar 16, 2017 | 1998 Dodge Dakota
Canon 400d will not switch on
it might be a problem with the battery connectors.
They might not touch the battery well.
another reason, it might be the battery is dead or the power button is not working.
Aug 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Jun 20, 2008 | Magellan GPS
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Open Questions:
See all Peg Perego John Deere Gator HPX Ride on Toy Questions
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
