Question about Sharp Office Equipment & Supplies
How can i reset the drum life over in sharp fax machine model FO-1S115N can you please give me a solution to my problem.
5 Suggested Answers
SOURCE: Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Posted on Jan 16, 2008
  • 1003 Answers
SOURCE: Changing Drum on Fax Machine
yes its as simple as changing toner cartridge
Posted on Jan 17, 2008
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
JayBlair
  • 328 Answers
SOURCE: How to reset drum counter
lift up the rapid key flap on the keyboard. press the life key and I think the display will give a choice of press 3 key and enter.
Posted on Oct 31, 2008
Tip
How to get the page count for a Sharp FO-5700 fax machine
Sharp makes a line of fax machines, one of which is the FO-5700. The FO-5700 is easy to maintain and to use, and it can run well for years. If you want to view the life counter (page count) for your FO-5700, just follow the steps below.
With the fax machine on and ready, flip up the bar that displays the information for half of the quick dial buttons (#17-32). This bar has a tab that you can use to flip it, which sits right by the panel release lever (where you would put your hand to raise the operation panel if you had to remove a paper jam there). Just flip this bar up so that it covers the first half of the numbers instead of the second.
Once the bar is flipped up, you'll see that the V button is labeled "Life." Press that button to bring up the counter menu. Then press 1 on the fax machine's number pad. The screen will display "1: Life Counter" and below that, "LIFE=xxxxxx" where "xxxxxx" is the page count of the machine, in six-digit format.
You can view this life counter at any time, without having to print out a configuration page or usage page. To exit out of the life counter screen and return to the main screen, press the red Stop button. Be sure to flip the contacts bar back to its original position; there is a sensor that detects which way the bar is laying, and if it's still in the up position, pressing a button will have a different effect than it would if the bar were in its original position (such as bringing up the life counter instead of dialing a number).
on Jun 12, 2011 | Sharp FO 5700 Plain Paper Laser Fax
Fo 5900. Replaced drum. Why is it still indicating 'drum life reached'?
There is probably a drum life monitor in the software that needs to be reset.
Nov 08, 2011 | Office Equipment & Supplies
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
LIGHT IS STILL ON WHEN i CHANGED THE DRUM ON THE
clear the drum counter. life than down arow until it says drum counter clear than start 2 times
Mar 23, 2009 | Sharp FO-DC535 Fax
Life button on Sharp FO 5550
Look at your rapid speed dial keys from a to z you need to flip over your page plate.
Jan 14, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Oct 30, 2008 | Sharp FO 4450 Laser Fax
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Jeff
Sep 19, 2007 | Office Equipment & Supplies
336 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
