Question about Casio Watches
How do i change the strap size on my casio A163W watch?
  • 73 Answers
SOURCE: How to adjust the straps and time on a Casio AQ230A-7B
For an instruction manual go to the following link.
http://world.casio.com/wat/download/en/manual/
Posted on Dec 31, 2007
SOURCE: I'm looking for a replacement
You can try calling Casio derectly 1-800-836-8580 If that doesn't work your out of luck unless someone has one they don't need. What is wrong with the one you have? sometimes the band can be repaired. Also some watch people or jewelers who can take a band alot like yours and cut it to fit the watch. Let me know what happens, maybe I can help you.
Posted on Apr 23, 2008
indays
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
escapement
  • 2334 Answers
SOURCE: can I get a replacement
Try to visit www.timex.com/ - 12k - Cached - Similar pages
If you can not find anything there, you need to go to your nearest watchmakers shop and ask for help.
Posted on Dec 21, 2008
Techjoel
  • 79 Answers
SOURCE: New watch strap
I got mine from ebay. Its tough to install but I used a pen knife and a very small sdrewdriver. you can do it.
Good luck,
Techjoel
Posted on May 11, 2009
What is the wideness of the strap? I want to change it, and I don't know which strap's size should I buy.
At the point where the strap attaches to the watch - take a ruler (with metric on it) and measure the mili-meters (MM's) between the LUGS (points of attachment). That will give you the size of your band.
Dec 09, 2014 | Casio American Apparel Womens Silver...
Broken Casio Wave Ceptor WVA-510A strap
I found a company in the u.k. www.watchbattery.co.uk, good price on Casio bands, pretty good shipping charges too.
Nov 29, 2012 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
Jul 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio gw-500, trying to change the bands, screws keep turning
For G Shock GW500Uthe screws holding the ******** are actually just one pin per strap the screw end is for decoration. To remove just get small headed flat screwdriver and push pin through it is fidely but can be done it took me 10 mins first time. Casio sell straps direct for about 10 pound cheaper than putting into casio dealer .
Jun 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Where to go to change the old strap?
    mcdevito75 here, Ebay has a wide variety of watch straps, you can also look for a small watch repair shop in your area for that new strap, of course you may have to order from Casio, just in case you do, here is Casio"s contact info, 800-435-7732
    Aug 11, 2010 | Casio Baby-G Wristwatch
    New watch strap
    Good luck,
    Techjoel
    Feb 17, 2009 | Casio G-Shock G3110-1V Wrist Watch
    Strap
    If you ever need a watch band for a casio watch just call their parts department and they should be able to send out one for whatever model of watch you have. Their number is 800-223-2001
    Oct 06, 2006 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
    Watches Logo
    391 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
