I have a Roper washer machine part # 3954259. I started a load of laundry and when it gets to rinse it shuts off. I have tried to go to spin cycle and it will not work either. What can I do? I have a load of wet soapy towels.
Krazytech
  • 725 Answers
SOURCE: clothes soaking wet after cycle completed
looks like you washer is not spinning your clothes out and maybe not agitate them either. Start your machine normaly on heavy load, watch it and check if it fill and moves back then drains and goes into a spin.. if water is still in the machine then you may have something stuck in the drain. If it fulls and drains then you may have a motor or control problem. If its still under warranty you will need to call authorized repair service or authorized frigidaire service. if not under warranty and you want to repair it yourself let us know and we can help.
Posted on Sep 15, 2007
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
  • 6 Answers
SOURCE: Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 08, 2009
prawinmv22
  • 106 Answers
SOURCE: Kenmore Front Load Washer, 417.44082400, will not
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on Jun 12, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My roper wont do anything
Is you washer sitting on a carpeted floor? If so ther is not enough air flow under it for the motor to not overheat. Maybe by now 4-3-09 it's functioning if not post me your model number. If it's on carpet raise it up with 3/4 inch boards under the feet.
Mar 09, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Whining on spin cycle
There could be something in the pump .If you can tip the machine back and remove the belt try to spin the pump pulley by hand if you hear the noise that's it if not call for service.
Jun 25, 2008 | Roper RAB2121KW Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
