Question about LG LRTBC1825T Top Freezer Refrigerator
No coldness Fridge Freezer not getting cold-lights and fans working.
  • Anonymous May 05, 2008
    PLEASE GIVE THE SOLUTION FOR NO COLDNESS IN MY REFRIGERATOR.tHOUGH LIGHT IS ON.
    Regards
    Champion:
  • 210 Answers
Are the lights that you are talking about in the controls? When some of the lights are on this is giving you an error code. Could be the thermal fuse has blown which would not allow the unit to go into defrost. If this is the problem, and you unplug it, it will run again for 5-7 hours until it hits defrost cycle again. You will need a service call.
Sgt 48
Posted on Jun 02, 2008
Just had this problem last weekend, Tech replaced the starter and op check good. $100.00 out of pocket. not covered by sealed component 7 year wrnty
Posted on May 21, 2008
  • 489 Answers
There could one of 3 separate problems going on but without fully knowing what's going on, I can't exactly tell you what to look for.  You will probably need a qualified LG technician to see what's going on.
Posted on May 11, 2008
4 Suggested Answers
  • 1462 Answers
SOURCE: cold air circulating fan
behind back panel inside freezer. take back panel off
Posted on Oct 20, 2008
  • 118 Answers
SOURCE: LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Posted on Oct 26, 2009
  • 256 Answers
SOURCE: Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Posted on Feb 19, 2010
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Jun 06, 2010 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRTBC1825T Top Freezer Refrigerator Logo
94 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
