Question about Goodman Heating & Cooling
Hi I have commercial hvac goodman unit and trying to change my filter, but i have no idea where the filter is located. the model number is GPG13480903AB
  • 407 Answers
On this package unit, there are no places for filters inside the unit itself unless a technician rigged something up to accept one, but not a common thing at all. These units will use filter return grills inside the building. They are usually 2x2 grills on a dropped ceiling grid or could have a filter grill located right off the return plenum from the unit. Either way, it should be inside somewhere and easy to access. Hope this steers you in the right direction and good luck!
Posted on Aug 26, 2010
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
New a/c goodman unit last year air coming out of vents not cold but everything seems to be running fine
Hello, this could be due to a lack of airlow or a low regrigerant charge. First check the air filter and make sure it is clean, make sure the blower motor wheel is clean and not dirty, also it would be a good idea to check tne evaporator coil and make sure it is clean. If the unit does not have any airflow problems most likely it is low on refrigerant due to a leak, in this case you will need a hvac tech to come out and repair the leak and charge the unit back up with refrigerant.
Jun 01, 2011 | Goodman CLJ36AR42 Air Conditioner
Where is my goodman serial number located?
Serial number will be on a tag on the electrical box cover near the top of the unit...the top number is the model and the next one down is the serial
heatman101
Aug 31, 2010 | Goodman Heating & Cooling
Looking for a parts list/owners manual for an old carrier AC unit. Model #38 REO 36 300. Any idea?
Follow this link to the search page for the Unit need need literature on. If you want to change models (i.e. from the 38BR to the 38RE, both of which you list in your question), just enter the 1st 3-4 characters in the search box. this link is for the 38RE. Good luck!
http://www.commercial.carrier.com/commercial/hvac/technical_literature/1,3063,CLI1_CNT1_DIV12_ETI9039_MID4442_QRYY,00.html
May 27, 2010 | Carrier 38BRC036 Air Conditioner
How to change the filter ?
Your filter is in one of two places.
Either its in a filter grille or its at the furnace/air handler itself. If its in the grille, simply remove and replace.
If its in the unit, it will be at one far end of the unit opposite where the electrical connections are. It's uncommon for Goodman to be filtered at the unit as they do not have an independent filter access panel but I have seen it.
If its not in either of these locations, you either do not have a filter installed or your installing contractor has installed a filter box somewhere that will need to be located.
Hope this helps.
Jan 10, 2010 | Goodman CLQ36AR49 Air Conditioner
2 yrs old, getting a 4 flash alarm , "Open High Circuit" any help?
check for a reset able round limit switch in the burner area if fires up make sure filters are clean and no signs of flame roll-out in the burner area when fan comes on this furnace should still have mfg parts warranty left
May 16, 2009 | Goodman GDS80904BNA Open Flame Heater
Cannot Find where air filter is?
You are looking for a thin cover that is held on with 1 or 2 screws.
(The one pictured in the circle,Yours may be located in the middle or opposite end)
Example:
Please rate this a fixya
Feb 09, 2009 | Carrier Heating & Cooling
Goodman unit freezing outside the unit
Its not the thermostat.
The things that can cause this problem are lack of or poor airflow over the Evaporator coil. Or a low system charge. Or quite possibly a restriction in the line on the low side. When they replaced the compressor did they purge the line set with nitrogen and pull a deep vaccum? This is imperative when replacing a condensing unit to ensure that no residual particles are left in the line set to create a restriction.
Hope this helps You
please rate me
Jul 24, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
