Question about Sharp AR-5320 Black and White Copier
MY AR 5520S flashes F2 and When you press the Start Key it displays 40. It would not copy nor print.
  • 3 Answers
Replace toenr cartridge or toner cartridge chip
Posted on Aug 30, 2010
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
F2 error code
You have used wrong toner cartridge....please use this model AR 202T
Jan 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Blinking U Blinking 2 in Display
When you press the copy key , it should show 40 and this is the solution. Remove the TD cartridge and unscrew the toner sensor and wipe with a small blower. Clean with a brush if the toner particle is stubborn and blow. Then screw back and clear with key press #*C* and enter16 then press copy key. If it re-appears, replace TD cartridge with Sharp AR-202ft. Enjoy the job.
Jan 07, 2011 | Sharp AR-M205 Copier
My sharp ar 5320e copier display me f2 code what shoud i do
Does it show if it is a f2-00 or any # after that? Sometimes you have to press the start key to display the rest of the nubers.
Oct 18, 2010 | Sharp AR-5320 Black and White Copier
My Copier is showing 0-8 problem and is not working how to fix it?
Try reset the error by following this step :
Perform the following procedure to enter the simulation mode.
["#" key] [Interrupt key] [CLEAR key] [Interrupt key] [1] [4]
[START key]
The machine will be reset and hopefully your trouble too.
When the CLEAR ALL key is pressed, the simulation mode is cancelled.
May 26, 2009 | Sharp Office Equipment & Supplies
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-157E digital copier
sir i have a problem with sharp AR-5320 copier it blinking H and 4 can you help me please
Jan 15, 2008 | Office Equipment & Supplies
Sharp AR-5320 Black and White Copier Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
