Question about HP OfficeJet J4580 All-In-One InkJet Printer
The page's print skew/off alignment. When I try to re-align the cartridges I get "Page Skewed please re-scan" then followed by "Alignment failed". Any suggestions?
  • garethbowley Aug 24, 2010
    The reset did not sort the problem. How do you suggest cleaning the rollers and how do I access them? How many rollers are there to look for and clean? What would you clean them with?
    thanks
    GARETH
    Guru:
  • 731 Answers
Please try the below resets one after the other (if 1st reset did not work)
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Posted on Aug 25, 2010
  • Mohammed Rizwan
    Mohammed Rizwan Aug 27, 2010
    Hi Gareth,
    Please check this link, which describes cleaning roller with pictures.
    CLICK HERE
    Regards
    Riztech
  • HP Master
  • 4,924 Answers
  1. Disconnect the power cord from the back of the product, and then wait for 20 seconds.
  2. Press and hold # and 3 on the product control panel while connecting the power cord to the back of the product.
  3. Release the buttons when the product turns on. The reset is complete.
this is for to reset the settings ..to factory ..
Posted on Aug 24, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Aug 24, 2010
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    use the info in this hp support page for to make a alignment again ..
    If the issues still goes on ..than the problem is from the rollers..clean them and see to be all in place ..and functional ..cause if the traction is not even ..than the page will behave strange and skew aside..
    thanks
    GARETH
    thanks
    GARETH
Slow printing
Remove both cartridges, switch off printer and then on. After cartridge holder comes to the center install both the cartridges. Then it will print the Alignment page. After alignment page prints place the Alignment page on to the scanner and press SCAN button as mentioned in the Alignment page. After completing the scan try printing. It will print the usual speed.
Note: For the alignment process both cartridges should in good working state
Jan 24, 2013 | HP DeskJet F380 All-In-One Printer
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Print head seems to be out of alignment. Lines of print seem skewed and blurry. Edges of pictures are not in alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Mar 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
How do I fix :Alignment Failed due to the alignment plot in the scanner being skewed
The alignment page was not placed properly on the scanner. You can follow the instructions here http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01367400&cc=us&lc=en&dlc=en&product=3390949
Try the alignment again it should work. Good Luck
Jul 28, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hi have a lexmark x2530. printer does not print word doc pages. will only print alignment page.
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
May 06, 2009 | Office Equipment & Supplies
Keeps wanting to print alignment page
To align the cartridge from the control panel:
Apr 20, 2009 | Lexmark X2470 All-In-One InkJet Printer
Changed black cartridge. Machine works fine, but
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Alignment of cartridges
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
Trying to align heads, 5610 HP all-in-one
This seems to be an issue with the alignment of the printer.
Remove both the cartridges from the printer and clean the cartridge contacts with a soft lightly moist cloth and then re-insert the cartridges. Unplug the USB cable of the all-in-one and then let the all-in-one perform the alignment process and once it prints the alignment page. Once the alignment page prints out, place the alignment page (With the printed side on the scanner glass) and then press the Scan button. the alignment process should complete successfully.
For more information, refer the below hp document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442099&cc=us&lc=en&dlc=en&product=441125
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet J4580 All-In-One InkJet Printer Logo
156 people viewed this question
Seeker5211
Seeker5211
