Question about Toshiba Satellite U205 Notebook
I need to reset to factory settings. How do I do this?
  • tclousel Aug 24, 2010
    I do not have any recovery discs. Is there another way to reset to factory settings on a toshiba satellite u205
  • 2,296 Answers
Read my instructions on this link on how to restore the factory settings: http://www.fixya.com/support/r8417061-restore_laptop_original_settings
Posted on Mar 02, 2011
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
Factory reset
Bro You Don't Need To Restore Factory Your Computer Just Renew Your Windows
It Will Automatically Reset The Factory Setting
Nov 06, 2013 | HP Pavilion zd8000 Notebook
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Jun 26, 2011 | Computers & Internet
How to format nokia xpress music????? pls help me....
Soft Reset The reset will restore all the phone's settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory, including take off your memory card.
  1. Switch off the phone.
  2. Press GREEN + RED + CAMERA + ON simultaneously until you see the "Select Country" option.
Note:
  1. The default password is 12345. You need to press and hold the key until the number appear.
  2. Please do not confuse "revert to factory settings" with soft reset. "Revert to factory settings" can be achieved from Menu > Settings > Phone > Phone mgmt. > Factory settings or *#7870# code, and will only restore the phone to its factory setting without deleting data.
If this answer helpful RATE please
Jan 29, 2011 | Nokia 5800 XpressMusic Smartphone
I forget my nokia 5800 password. pls tell me
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
Note:
Nov 10, 2010 | Computers & Internet
I need code of nokia 3600 classic reset factory setting
To restore to factory settings you no need any codes.
Please follow the below steps to restore your mobile to factory settings
Menu > Settings > Restore factory settings
When you select this,It will ask for security code.The default security code for nokia mobile is 12345.If you have changed the security code then type that code.
It takes several seconds to bring it to factory settings.
Thank You
Aug 07, 2010 | Cell Phones
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Feb 09, 2010 | Yamaha RX-V1000 Receiver
I need to reset my toshiba l300-1f0 to factory settings with out
http://en.kioskea.net/forum/affich-58528-reset-toshiba-to-factory-settings
Oct 08, 2009 | Computers & Internet
Toshiba Satellite U205 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
