SOURCE: Torque 1998 Tiger Shark 770 jet ski, blew out head cover gasket.
Inside-out in a cross pattern. Cases/cylinders 25 ft./lbs., Head 22 ft./lbs.i
SOURCE: how to replace seal on a jet ski
The seals in the drive pump can be replaced by taking off the ride plate and pump housing. To replace any other seals (engine or hull) you will have to remove the motor from the hull.
If the seal is in the jet pump, get an impellor tool and replace all the seals and bearings in the jet pump. You will have to pull the engine to replace the crankcase seals or the rear hull seal.
SOURCE: Our bildge pump still puts
You can get all kind of bilge pump related documents here: http://manuals-market.com/search.php?cmarque=PERFORMANCE%20TEKNIQUE&modele=ICBM%20779. Afterclicking this link you will be forwarded to a page contains a form. You need tofill up that form. Most of them are pre-filled. You need to write "bilge"in Brand box and model number in "model number" box. Please don'tforget to mention "type of product" in the "description box".Finally accept their "terms and condition" and click on "search"tab. Under "Typeof Document" you will find schematics diagrams. Download documents as per yourrequirement. Hope this will help you. Good Luck.
