Question about Toro Lawn Mower With Toro Power Tools
Toro 52" proline, blades engage then shortly blows fuse, clutch wires get hot if larger amp fuse is used but blades continue to work. Bad Clutch? clutch adjustment? other ideas
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
lilmikew99
  • 122 Answers
SOURCE: Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
Posted on May 10, 2009
#1 Taper
  • 1040 Answers
SOURCE: toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Posted on Jun 09, 2009
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
  • 320 Answers
SOURCE: My Toro LX425 keeps on blowing 20 amp fuses when I
a fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
Posted on Jun 29, 2009
I have a husqvarna LGT2654 it blows fuse brought in for sev was told to clutch shorted but unplugged pro and fuse still blows fuse any ideas
If the tractor blows fuse while the engine only is running, you may have a hot wire grounding out. If the fuse blows when engaging the blades, the PTO switch or electric clutch is the problem.
Aug 01, 2017 | Husqvarna Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
20 amp fuse on Model 125A blows when blade engaged
There is a short in the electric clutch or the clutch just plain went bad and needs to be replaced... I would check all the wires going to the clutch for rubbed spots where the coating is rubbed off and bare wire is hitting the metal...
heatman101
Aug 29, 2010 | John Deere Garden
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro Lawn Mower With Toro Power Tools Logo
123 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
