Question about LG 42PC3D 42 in. Plasma Television
Tv won't turn on and I've checked the obvious like yes the power cord is plugged in yes I've switched the batteries in the remote so I know that is getting power
  • LG Master
  • 8,457 Answers
Try tv unplug,replug it about an hour later,let the tv reset it self.Still have the same problems.The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Aug 24, 2010
IVE HELD TV BUTTON FOR 5 SEC BUT DOESNT BLINK WHEN I LET GOundefined
On the remote? If in your mind you are turning the TV on the way you have a million times B4 and it isn't working this time then one would think " what has changed?" Well I was vacuuming behind the TV or the cat was back there or the kids were close to the outlet so i... At any rate go for the obvious first if the remote doesn't work try the TV directly. If the Front switch doesn't work then a lot of the bigger plasma's have a second power switch behind somewhere. Going for broke here... worst case scenario perfectly good TV will not turn on And all switches and cords verified good/"on" and plugged in Iv'e seen many times folks tried it all except the out was bad or so much junk in front of the out let you couldn't see it/test it if you wanted to. or have it plugged into a unit that only when IT is turned on does it supply juice to TV. OK devil's advocate..... everything you know about plugging stuff in and looking for indicators is OK in your eyes... and you've bypassed the pesky remote that cuts through cheap batteries like crazy.....Power switches these days don't go bad very often. And they're rarely a mechanical 'hard switch' anymore. A lot of times at the minimum a light will light or a set of capps start to charge with a distinctive snapping noise. Any lights? Any noise at all? what kind of TV is it? CRT? Flatscreen? Troubleshoot a bit and the odds are with you if it's a newer FS that its cheap and easy (and embarrassing) let us know what you find my friend ~~~~SC
Oct 28, 2014 | Televison & Video
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
The power light does NOT go off and the TV will not turn on. I know the TV works because every once in a while I will plug it in and hit the switch and it turns on. I tried programing a remote and then...
As far i can tell,u said the tv u unpluging,repluging the tv back awhile later the tv will function and work is that correct?Yes,this problems,alway related to the tv power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.U said u tried programing the remote,is the remote u have and using is a universal remote,u don't have the tv original remote?Yes,try website like Remotes.com to buy the tv original remote too.
Jun 20, 2011 | Akai LCT2060 Television
The tv wont stay on
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. if otherwise the power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 16, 2011 | Polaroid Televison & Video
I just bought a new 40 in. philips LCD television. I plugged the power cord into the tv then into the wall outlet. the tv will not turn on or make any sounds when trying to turn it on with remote and...
Hello, make sure power cord is pushed in all the way in to the tv. Also make sure you have power at your outlet. I know it sounds dumb, but I've seen people chase their tail for hours before coming to the conclusion that a circuit breaker was tripped. Make sure you have good batteries in the remote. If the TV has a power button on the tv, try turning it on there instead of the remote. You can check to see if there is an on/off switch in the back. Besides this it should be pretty straight forward. You might have a defective tv
Hope this helps
Thank you in advance for your feedback
Mar 04, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
LG 42PC3D 42 in. Plasma Television Logo
Computer Repairing
Computer Repairing
