Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung WA80T4G when power on and pressed start button drum not rotates,water not enteredfront panel desplys 45 after some time 4E.No sound.Not working
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
SOURCE: 4e code
i have problem error 31( E31) please advice me to solve this problem
Posted on Apr 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: 4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: 4E showing on Samsung Washing Machine
Posted on Sep 16, 2010
  • 6277 Answers
SOURCE: sir, panel is working
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Jun 28, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Wa80t4g model water supply is good but spin rotation is not working error is sometimes4e sometimes 5e what to do
    There is a safety switch engaged by the door or lid that cuts off power when open. Check this switch as they often cause this fault.
    Nov 29, 2014 | Washing Machines
    How do you get the water to drain in the Malber WD100 washer/dryer combo?
    Hi. I''m assuming you are referring to a WD1000.
    To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
    Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
    Motor won't turn on Samsung VRT Plus WF433B*GJ**
    When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
    To add a forgotten item:
    1. Press the Power button.
    2. Press the Start/Pause
    3. Wait for the door lock light to go out (Immediately).
    4. Add the item, close the door, and press the Start/Pause
    The door safety state continues for 15 seconds and the cycle is restarted.
    ensure thorough cleaning,
    To
    Try washing bedding, towels, undergarments,
    contact using the ActivFresh
    GETTING STARTED
    1. Load your washer.
    2. Close the door.
    Z_
    Push the laundry into the drum completely to prevent the laundry from being caught in the door or
    ....... from falling out of the drum.
    3. Press the Power button.
    4. Add detergent and additives to the dispenser (page 20-21).
    5. Select the appropriate cycle and options for the load (page 14-16).
    6. Press the Start/Pause
    7. The Wash Indicator light will illuminate.
    8. The estimated cycle time will appear in the display.
    The time may fluctuate to better indicate the time remaining in the cycle.
    The actual time required for a cycle may differ from the estimated time in the display depending on the
    water pressure, water temperature, detergent, and laundry.
    9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
    quick drain.
    When the cycle is complete, the door lock light will go out and "End" will appear in the display.
    DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
    "Loading your washer" section (page 13).
    When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
    continues.
    Pressing Power button cancels the cycle and stops your washer.
    The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
    Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
    Ac is automaticaly stop and desply message in screen E 3
    E-3. Indoor fan motor mechanism locked or no power to blower motor. Check manually by rotating. If rotate freely, check power to motor. If no power PCB defective. Replace it. If hard to rotate motor, replace bearings or motor. Helpful?
    Jan 28, 2011 | Samsung Heating & Cooling
    Samsung washing machine SW50USP. Machine powers up, all buttons and settings work but when press start button the cold light and wash light start flashing but doesnt start to wash. After 2 minutes 4E shows...
    I've just had the same problem with my Samsung SW50USP and had a technician out to have a look at it. Apparently the electronics are fried and it would cost much more than it's worth to fix. Time for a new machine unfortunately.
    Dec 26, 2010 | Washing Machines
    Drum doesn't really rotate on wash cycle.
    No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
    May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
    Jan 29, 2009 | Washing Machines
    Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
    132 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
