Gives ONLY Sky screen with bird on branch - no start menu or windows 7
  • danielkingiv Aug 24, 2010
    this is NOT a Barcode SCANNER Problem - it's a START-UP 'Blue Screen' problem - I don't know WHY Fixya is calling it a blue screen problem ???
    The problem with the E-Machines N214 Notebook - is that it has NO CD Drive (like most Notebook computers) - but has an internal RESET to factory DEFAULT mode - but i can't get to System Restore w/o a Start Up menu ???
  • 11,800 Answers
Multiple causes could generate that. The most obvious one is that the Windows was corrupted. Try to boot in the BIOS. If you can't then there's a hardware failure and to identify it you need to swap components - if you don't have replacement ones then take it to a shop, there's nothing more you can do.
Posted on Aug 24, 2010
  • Azrael SRL Aug 24, 2010
    In your laptop the Recovery is a hidden partition on your hard disk. But if your hardware is faulty you will not be able to access it. As i said try to boot in the BIOS and see from there.
Increase internet speed
Hi,do the following step by step instructions to increase your Internet Speed:
Step 1 : First of all Click on start button.
Step 2 : Select the run button from the start menu or type Run and click on it.
Step 3 : Type gpedit.msc
Step 4 : Expand the Administrative Templates branch
Step 5 : Now expand the Network branch
Step 6 : Click on the Qos packet scheduler
Step 7 : Double click Limit reservable bandwidth
Step 8 : Check the enabled
Step 9 : Change bandwidth Limit to 0 %
Step 10: Click the Apply button and OK.
Step 11: Now restart your PC.
Step 12. check if its now better.
Before and after doing these steps check your internet uploading and downloading speed results in both MBps and Mbps units from Scanmyspeed.com .
Dec 23, 2013 | TP-LINK Computers & Internet
Some problems in laptop
Have the hard drive tested for issues, from your description it is the harware that is causing the problems.
Jun 27, 2012 | Computers & Internet
What type of bird stand should I get for my parrot?
The physical and mental stimulation is extremely important for parrots, so get a bird stand with climbing room, toy hooks and food bowls. As your bird climbs the branches, searches for treats and plays with toys, he will be active and experience the sense of being part of a flock.
May 14, 2012 | Birds
Ok.. I am no tech expert so I may need some help & expert advice on this one. I bought (rather received a gift) around 2 months back - a Sony VAIO E series VPCEA13EN. All was fine until two days back...
To get safe mode and depending on the machine you need to press and hold f6 or f8 just after the intial boot screen shows. This will allow you to get to safe mode selection on your pc.
Oct 10, 2010 | Sony Computers & Internet
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
Sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Feb 20, 2008 | Televison & Video
Blurry pictures
Try differential focus That is point to something near the distance you want- half depress the button -turn to subject complete the press down Bear in mind that if the subject is really close to the view finder is not looking where the focus window is-Parallax- learn to shift you frame slightly to allow for this.
May 13, 2007 | Canon PowerShot S2 IS Digital Camera
Computers & Internet Logo
David Payne
David Payne
