Question about Sunbeam SMW777 Microwave Oven
700 watt microwave started smoking, and it smells like something electrical burned up.new under 4 months ago. Sunbeam
  • 958 Answers
SOURCE: Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Posted on Feb 18, 2008
grandadfixer
  • 99 Answers
SOURCE: Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Posted on Oct 11, 2008
  • 13 Answers
SOURCE: ge microwave oven wall smelling wire burn!!!!
time to put it to rest
Posted on Jan 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
  • 99 Answers
SOURCE: sunbeam 700 watt micro shut off while in use now nothing comes on
it is problem power supply or panalboard unite,If you are not a technician,please go to a service center.
Posted on Dec 06, 2009
Microwave heats but makes smoke and smells like something burning inside. Help!
I would first be sure the inside is clean of grease and food debris. That's always critical.
Next I'd suggest removing and checking / cleaning the stirrer cover, stirrer, and the area under the cover and around the stirrer.
That's covered on page 33 of the service manual here.
That too should be clean.
If it still smokes, you may have a failing high voltage transformer.
You can order Maytag parts here.
Nov 30, 2012 | Maytag MMV5165 Stainless Steel 1000 Watts...
I need an owner's manual for a sunbeam microwave 700 watts model#SM0701A7E
For assistance with your Sunbeam Microwave, you can call 1-866-257-3336.
Dec 15, 2011 | Sunbeam Microwave Ovens
Push start and a loud deep buzz then the smell of electrical wiring burning and smoke fills the cavity.
You have something major wrong with your microwave. May be time to replace.
Sep 21, 2011 | Microwave Ovens
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Sunbeam SM777 700 WATTS
This is most likely a simple problem or a bad door switch or door switch mount. See this file.
It should answer all your questions so you or someone you know can fix it pretty easily.
Jan 29, 2010 | Sunbeam SMW777 Microwave Oven
Sunbeam 700 watt micro shut off while in use now nothing comes on
Dec 06, 2009 | Sunbeam SMW777 Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Oct 10, 2008 | Thermador MBBS Microwave Oven
Sunbeam SMW777 Microwave Oven Logo
50 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
