Question about Refrigerators
Every time door is opened it beep straight away and makes a whiring noise. This happens with fridge and freezer compartments.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My whirlpool sixth sense fridge freezer is reading F01% (fridge side) the motor seems to be overworking(making noise) but doesn't;t do so when fridge door is open. The freezer seems to be fine and...
the motor is suppose to stop when the door opens and turns on when closing the noise could be ice building up and the fun blade rubbing the ice if unit is empty you should leave the unit disconnected so ice melts and noise will go away when reconnecting if no motor replacement is needed.
Dec 26, 2014 | Whirlpool Refrigerators
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Apr 12, 2014 | Whirlpool Refrigerators
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Noise from Deodorizer
Sounds like the circ. fan may be hitting something or has a blade broken off. The refer gets cool air from the freezer section to cool it so the fan aids in the circulation along with vents/dampers, etc. to move air into the refer compartment. If that fan is broken off the motor shaft or something then the motor can run but no air will move. See if you can feel air moving out of the vents, it will be a little bit of "blowing" not a huge wind. A wet hand can help feel for wind. I believe the deodor light may indicate a change is needed (but check the owners manual for actual meaning). If there is no air flow open the freezer section and see if the air flow is noticed then... if a air channel if frozen and can't draw air from the proper area, opening the freezer door will give it outside air and you may feel flow then, that would tell you of a frozen air channel issue.
Oct 16, 2006 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
