Question about Garden
Runs for 5-6 seconds and quites! - Garden
  • 7,482 Answers
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
98 Plymouth voyager makes clicking sound for like 5 seconds coming from glove box after starting. Runs and drives fine.
It sounds like a vacuum problem. Your vents are positioned by a vacuum. It may take only the first 5 seconds to stick or decide to quit. See if it makes a difference if you are recirculating air or getting fresh air.
Sep 14, 2016 | 1998 Plymouth Voyager
Runs for a few seconds and then quite
It could be a fuel pump issue, do you hear the fuel pump run when you turn the ignition to run position? Just turn the key to on (turn the radio off and buckle the seat belt so you can hear better) you should be able to hear the fuel pump. It will be a hum from the rear of the car, the pump should run for 3-5 seconds then shut off.
Dec 04, 2009 | 1989 Ford Escort
Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
Jun 25, 2009 | Acer Aspire 3003LCi Notebook
1998 dodge caravan, engine runs on for 5 seconds, key removed...
( times out of 10 Hun its the Timein on it take it in for a Tune uP or get the Timin light and do it your Self
Mar 06, 2009 | 1998 Dodge Caravan
Heater will not stay running
Spark plug or hot surface ignitor?
Nov 18, 2008 | Reddy R60A Utility Heater
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
