Question about Brother GX-6750 Typewriter
HOW DO I REMOVE THE RIBBON - Brother GX-6750 Typewriter
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around you will find a downloadable manual there.
DickyO
Posted on Aug 24, 2010
Remove har drive
It is used to pullout the harddisk no problem if you pulled out .if placed means easy to pull out thats it.
Feb 14, 2014 | Sony Vaio S Series Vpcse190x...
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
How to disconnect acer ribbon cable
The ribbon cable to what?
Some ribbon cables have a connector on the end of the cable, in this case just pull the connector or the ******** the connector to remove the ribbon cable.
Other ribbon cables are locked into the connector by a slide bar across the ribbon cable that you move the ends of the bar away from the connector to release the ribbon cable.
May 14, 2012 | Acer Computers & Internet
We have an lg microwave oven with the control pad on bottom of door...removed pad by lifting on sticky stuff but it is attached with a circuit board ribbon, How do I remove the ribbon
where the ribbon cable makes connection to the control board there is a plastic insert around it you need to grab one both sides just the plastic piece not the ribbon and it will pop up approx 1/8 inch to 1/4 inch and allow the ribbon cable to come out..there are two small holes that are in ribbon cable once you remove you will be able to see that align with 2 plastic tabs so when pressed down the ribbon cable connects with the control...good luck to you
Jan 06, 2011 | Microwave Ovens
How do I install the ribbon in my 8014s typewrter?
Swing the red lever on the R. side of the cassette to the front, remove old ribbon, wind new ribbon until slack is gone, put the ribbon behind the 2 black ribbon lifters, snap ribbon into place, move red lever back home, done.
DickyO
Nov 09, 2010 | Swintec Office Equipment & Supplies
How can i remove the keyboard of a compaq hp nc 4200
Remove the cover for the power strip under the screen,push the keyboard forward and it should lift up.Remove the power ribbon from the motherboard by lifting the securing strip next to the ribbon where it goes in and the ribbon should come out.
Oct 09, 2009 | Computers & Internet
How can i remove the ribbon cartridge of EPSON LX-300+ii?
open the top cover and pull up the cartridge if ribbon stock near head pull properly...........
Oct 09, 2009 | Epson Dot Matrix LX-300+ II Printer
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Ribbon install
open the black cover of your ribbon storage..remove the soiled ribbon. locate the origin of the ribbon( do not pull the ribbon hard as if you don't mess the arrangement) follow the pattern that has an outer pathway located beside to your original hook of the ribbon then pull the ribbon out gently (just follow the arrows that is indicated on the case)
Feb 05, 2008 | Zebra Z4Mplus Label Printer
Hot to change ribbon on sony m8800
Its not too hard to change. I have done this once before. Open main unit. Remove cd mech to get to the other end of the ribbon. Remove this end first. Manually rotate the motor worm gear until screws on head unit are visible. Install ribbon in head unit then main unit. Make sure the ribbon contacts and ribbon are positioned/routed the same way. Rotate that motor (end to end) again to see if the ribbon hangs up anywhere.
Nov 05, 2007 | Sony CDX-M8800 CD Player
Brother GX-6750 Typewriter Logo
13 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
