Question about OKI C3200n Led Printer
Mt toner is new but the maching keeps saying Drum near life. what is the problem. where is the sensors Roland
  • 10,515 Answers
For the Oki C3200 with No LCD, the replacement or addition of a fuse 422 012 or 422 006 to the drum unit will reset the drum life to 100%. Fuse is available from RS Online or www.rsaustralia.com
I used the 422012 yesterday and it worked perfectly on my Oki C3200 with no LCD.
You will need to remove the toner cartridge from the top of the drum (do this over newspaper). From the top of the drum unit where the cartrdige was, remove the left and right screws. Gently clip off the top unit, exposing the toner powder. There is another screw on the right which you may or may not have to undo. On the side of the drum unit where the blue lever would be, you should be able to see two copper pieces. The fuse will need to slot into the copper pieces to create a circuit between the two pieces. You don't need to solder, just push the wire ends of the fuse into the slots on the copper sqaures. Reassemble and place back in the machine. Once the machine completes its warm up and initialises, the fuse should blow and the drum counter will be reset to 100 or 99%.
The following website has a picture showing this http://printerdoctor.com/okidrumkit.htm BUT YOU DO NOT NEED TO to disassemble to this point to change the fuse. If you do it becomes messy and difficult to fully reassemble the unit to working order. I have only provided this link so you can easily locate where the fuse has to go.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 25, 2010
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
Toner life
You need to reset your Brother printer to get rid of the message
Mar 26, 2008 | Brother IntelliFax-2820 Laser Fax
I just installed a new drum and toner cartrideg last week and the error message says drum is near end. Should the toner cartride be replaced?
After replacing the drum and toner you may need to reset the drum life of the machine. This is how to reset the drum life:
Open the front cover where the drum and toner are located. Press the clear/back key. Lcd should show Replace Drum? Then press 1 for yes. Lcd should show accepted. Close the front cover the press stop/exit. Lcd now should show the date and time.
Hope this helps. Rate if it works. Thanks
May 02, 2011 | Brother MFC-8460N Laser Printer
Says toner life end and it's not ended. thanks. I also never reset drum button when got new drum how do i do that as well? thank you :)
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
Apr 14, 2011 | Brother DCP-8065DN Black and White Copier
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
What is the Drum?
The drum is a selenium coated sort of roller that has the image of your copy document tranfered onto it. As it rotates this image is tranfered to your new copy paper. It then is demagnetised and the toner returns to the toner catcher. The drum coating has a finite life and the mesaage is telling you that its life is near its end and a new drum or new machine will be required soon.
Mar 22, 2010 | Brother MFC-9440CN Laser Printer
When I replaced the drum I know get a 540 sensor toner error
Get another toner to fit to your new drum, what happens is the toner sits on the drum, and when you lock it on the drum it dumos as much powder from the toner container on top into the drum as it can. If the top unit runs entirly out of toner it will throw the sensor error, if you look at the drum you took out you will see it has the toner in it, so if you even just a put a new one in before you fitted the drum, you will need to fit another..
You can check if this is the issue by looking at the level of powder in drum unit, it should be up to the brim of foam edged slot not below it...then feel your toner if the top cart is empty then thats your issue ..fit another toner
There are other things but this is the most likly and I have given you a test to verify if this is your issue or not.. hope this helps oh and its a good idea not to change toner near drum life ends...or if you dont mind a little mess, before changing drum, invert your old one with toner still on top, while you are holding upside down , keep a firm pressure between both units and unlock the toner, turn upright and you now should have an near emppty old drum and the toner locked back in the toner cartridge ready to transfer its load to the new drum, rather than the expensive stuff heading for the bin......must be money in selling the stuff they want you to waste it....what a planet..cheers.
Nov 15, 2009 | OKI C5100n Laser Printer
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Toner life ends
There are two units in the machine, a toner cartridge and a drum unit. The toner clips into the drum and then is inserted in the machine. If you changed the toner and you still get this message, you may have a bad or damaged toner detection sensor.
Jun 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
OKI C3200n Led Printer Logo
308 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
